Author Topic: Honda CB750 F or A 4-1 header - any good?  (Read 1789 times)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« on: December 06, 2017, 07:26:14 AM »
Hi All,
   I am curious as to how well the 4-1 header and exhaust off of a 77-78 CB750F or A model works for a replacement for my 1971 CB750K model? My current exhaust is an aftermarket 4-2 model with large, Lake type pipe on each side, turned out to the side. The opening has to be 3" at least.
I have access to the 4-1 CB750F or A model, I believe it is anyway, as it came off of a 1970 CB750K0, and it looks like the stock exhaust off of a CB750F or A bike. I believe I could replace the rather long and heavy looking can on it with a lighter one. Would it perform as well as, say, a Kerker or Delkovic 4-1? I notice that it *may* block the oil filter housing, also. If anyone has had good experience running this exhaust, let me know. I am looking at weight reduction, ground clearance, etc. also as criteria for use. So... any good, or should I look elsewhere for a good 4-1 replacement?
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline slikwilli420
  • Master of Disaster
Re: Honda CB750 F or A 4-1 header - any good?
« Reply #1 on: December 06, 2017, 07:44:57 AM »
A stock 4-1 for these bikes in good condition is worth a pretty penny to a lot of guys. It also weighs a ton more than a good aftermarket system and probably wont offer any more performance than the 4-4 pipes your bike came stock with. Go with the Delkevic or Motogpwerks pipe for a nice light solution.
« Reply #2 on: December 06, 2017, 07:53:28 AM »
+1 on MotoGP exhaust, I put one on my K3 earlier this year.
He doest have one currently listed, but send him a message [or call], he may have one laying around...
https://www.ebay.com/itm/KZ-1000-STAINLESS-4-1-KZ1000-Z1-Z1E-YOSHIMURA-CALFAB-RACE-AMA-KZ-KAWASAKI-ELR/112671395940?hash=item1a3bbd1064:g:IE0AAOSwyYFZ~LGx
Offline Yamahawk
« Reply #3 on: December 06, 2017, 07:56:43 AM »
Thanks, slikwilli, it is in pretty good shape, has a little scrape on the muffler can, but the 4-1 header is almost perfect... it's at my friend Pat's cycle salvage, upstairs in the exhaust room. I figure it would look good, and looks like most of the weight is in that Looong can and pipe off the header lol. Someone must have taken it off of an F or A model and installed it on their K0. The tag says '70 CB750 on it.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Yamahawk
« Reply #4 on: December 06, 2017, 07:59:42 AM »
Steve-o, thanks for the heads up. His stuff looks real good. I was considering the Delkevic with a light slip on can, as it looks very light and well built. The MotoGP pipe looks pretty nice also... have to sell a couple things to afford that one, though ;)
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #5 on: December 06, 2017, 09:41:22 AM »
Even the header weighs a metric #$%* ton...it will give back a little low end... enough to offset the weight?...I doubt it.  It's really heavy.  Also the collector is slightly oddball and it's hard to get a standard can to seal well.
Offline Garage_guy_chris
« Reply #6 on: December 06, 2017, 11:58:09 AM »
also check out the Hindle pipes from http://www.ripplerockracers.com/product-category/exhaust-systems/ also very light and a similar 4-2-1 design
Offline Yamahawk
« Reply #7 on: December 06, 2017, 01:11:51 PM »
The Hindle exhaust is nice, also, I used a small Hindle can on a header for a Kawasaki EX250 I am building for the track, looks like a nice light system.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Bankerdanny
  • Endeavor to persevere
« Reply #8 on: December 06, 2017, 01:41:58 PM »
My 750F has what appears to be the stock header with a Kerker muffler. I haven't started it yet, so no idea about the sound, although based on the Kerker 4-1 on my 550F I expect it to be much louder than stock with a nice burble to it.
« Reply #9 on: December 06, 2017, 02:14:42 PM »
 I'm not sure if there is more than one A pipe but the ones I've seen aren't performance oriented. The 75/76F headers don't fit the k frame due to the brake pedal being different. 77/78F do fit K's.
 I like the delkevic for a 4-1 or DSS has the Yamiya stock no number pipes too.
« Reply #10 on: December 06, 2017, 02:25:22 PM »
Charlie you broke one if my rules,  fwiw..
Never ever, ever, ever or not even ever .....tell anyone on here where a nice piece that you are interested in is located.
If you then decide you don't want/need it, then and only then reveal where it us..
 Friendly advice fwiw..
Offline Yamahawk
« Reply #11 on: December 06, 2017, 02:55:41 PM »
Thanks for the info, it might be a 77-78F model then. Not sure if the 77A is the same or not, but he has parted out at least two CB750A models, as the engines are on the shelf.
Hehe... yep, good advice, for sure  ;)
But, I know that if something is in your path, there will be made a Way for it too. I am going to take a closer look at the exhaust system tomorrow, and see if there are any #'s on it or Honda markings anywhere on the header or can.
And as I once told another fellow, it is never, ever never or ever lol... only sometimes  ;D
Edmund Burke
Romans 8:28
Job 13:15
« Reply #12 on: December 06, 2017, 02:59:16 PM »
The Honda number should be stamped on the muffler
Offline Yamahawk
« Reply #13 on: December 08, 2017, 02:08:10 AM »
Ok, couldn't find any Honda numbers anywhere on this header/muffler, but here are a couple pictures of it in case anyone can identify it. The header collector is flat, so it doesn't take much ground clearance, too. I actually found a 1975 CB750F model up there, and it was quite a bit meatier and HEAVY!
Charlie
« Last Edit: December 08, 2017, 05:09:18 AM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
Offline Yamahawk
« Reply #14 on: December 08, 2017, 05:10:32 AM »
I added two of the same pic at first, now there is the view showing the flat 4-1 collector. oh.. and pay no attention to those CB550k pipes in the background... ;)
Charlie
« Last Edit: December 08, 2017, 05:13:32 AM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
« Reply #15 on: December 08, 2017, 06:08:46 AM »
If you use that on an f bike, you will have to source early model exhaust spigots.  And no Honda numbers because it is aftermarket.
Offline Yamahawk
« Reply #16 on: December 08, 2017, 06:19:43 AM »
Sean,
   It's going on a 1971 CB750K1, the tag on the exhaust says 1970 CB750, so it should fit my spigots already. Any idea who made this exhaust? I figured it was aftermarket after not finding any Honda #'s or logo's on it. So not sure exactly what it is, and how well it will perform... and, it's really not that heavy either. Not like the 1975 CB750F hanging opposite it, but it's not in either picture. I noticed the muffler has a bracket welded on it to fit the mount point on the K0 frame, so the pipe isn't really made to fit to early k's for some reason, or he just used a can he had laying around for the header.
Charlie
« Last Edit: December 08, 2017, 06:22:20 AM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
« Reply #17 on: December 08, 2017, 09:29:38 AM »
Oh that's right...forgot it was going on k1.  No idea what kind that is.  Somewhere here is an exhaust I'd thread.  Somebody needs to search it up as there is lots of good info therein
Offline Yamahawk
« Reply #18 on: December 08, 2017, 10:00:58 AM »
Thanks! I will search and see if I can find it
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #19 on: December 08, 2017, 10:09:23 AM »
It is set up for spigots, may be a one off.
 Bet it won't fit an F, which wasn't invented when this was built.
Offline Yamahawk
« Reply #20 on: December 08, 2017, 02:39:12 PM »
Yeah, I am not sure of this pipe, either. Definitely NOT an F pipe, but then, it may be just an early 4-1 header for the CB750. Perhaps he had a spare can laying around, and installed it on his K0. I know it should have good ground clearance with the flat collector, just not sure how well this design would perform. Most collectors are 4 square, and then taper into a single outlet for the muffler can or pipe to flange to. But, if there is evidence somewhere as to how well this header system works, that would be cool. I could install it and try it out, but winter is coming fast lol... may have to wait for the global warming I am praying for ;)
Charlie
Edmund Burke
Romans 8:28
Job 13:15
