Author Topic: Larger than 674?  (Read 1938 times)
Larger than 674?
« on: December 07, 2017, 02:12:25 PM »
Has anyone (other than Paul) built their 650's larger than the Dynoman 674 kits? Meaning installing larger sleeves plus the need to bore the upper engine case holes to suit.
If so I am curious if the cylinder base/top case was difficult to seal against oil leaks after?
Offline Camrector
Re: Larger than 674?
« Reply #1 on: December 08, 2017, 09:08:17 AM »
I had an issue with a leak from the base gasket using the 674 kit....cause I’m a bonehead!!!! ;D ;D ;D
I’m loving that your on this mission Brent!
« Reply #2 on: December 09, 2017, 07:21:01 PM »
What made the leak?
Offline Camrector
« Reply #3 on: December 09, 2017, 08:25:24 PM »
Pinched the base gasket Mark.  :(
Offline Camrector
« Reply #4 on: December 09, 2017, 10:57:48 PM »
Brent
Can’t remeber Paul’s final cc, but didn’t he just use cb750 pistons?
Go 836!
« Reply #5 on: December 10, 2017, 10:23:10 AM »
I think Paul ended up with 64.75mm, maybe 65. No matter what I won't risk reliability, so still measuring options at this point. I would really like to know the length of the 350/400F top end studs, or APE HD equivalents. I asked in the other section but no answer.
Boring for 62mm pistons must leave the bottom of the 650 sleeve taper wall thickness very thin, probably just 0.051"?
« Reply #6 on: December 23, 2017, 09:44:16 AM »
That's to thin for me....you can get cracking easy.
« Reply #7 on: December 23, 2017, 10:16:19 AM »
I agree Mike, but from my quick measuring those 62 mil pistons must leave the sleeve that thin. Do you know? Changing to 750 sleeves and 64mm pistons will leave about 0.076" which is still on the thin side. But with a short skirt may be manageable.
Offline Camrector
« Reply #8 on: December 23, 2017, 03:42:26 PM »
Thin to win?
« Reply #9 on: December 23, 2017, 05:37:58 PM »
There are tons of 65mm bore 836 bikes out there, some of which have been running for decades without cracking the sleeves. ???
« Reply #10 on: December 28, 2017, 02:25:11 PM »
True Scottly, maybe the guy with the caliper has a problem!!
