Author Topic: Cracked Case ?  (Read 1424 times)
Offline rddcw
Cracked Case ?
« on: December 10, 2017, 08:35:45 AM »
When I purchased this CB 750 K4 last year, I noticed that it weeped a little motor oil under the engine appearing to be coming from underneath the front sprocket cover. I pulled the cover off and examined the case area in front of the sprocket. It looked to be cracked thinking that possibly the chain broke prior in the bike's history of use ?
I read somewhere on this Forum saying that throwing drive chains were common in that era but probably due to the fact how the bike was maintained and ridden ?
The crack is located on the bottom half of the case. I smeared a little RTV in that location which helped a little but still weeps after being ridden when the oil is warmed up well.
So my question is without spitting the cases and repairing the crack correctly, is there another "band-aide" that would work better than the RTV ?
Re: Cracked Case ?
« Reply #1 on: December 10, 2017, 09:12:16 AM »
 Roughing up the area and thoroughly cleaning for good adhesion for some JB Weld to be slathered over the crack.
Offline dhall57
Re: Cracked Case ?
« Reply #2 on: December 10, 2017, 09:32:34 AM »
How about a pic rd. Not saying you case isn't cracked but the 74's still had the chain oilers and they can be messy causing oil do drip and that could be the issue and that would be great if it was because that can be adjusted or completely turned of. The sandcast and KO's were noted for breaking chains leading to a broke case not so much the later models.
« Last Edit: December 10, 2017, 09:45:36 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline rddcw
Re: Cracked Case ?
« Reply #3 on: December 10, 2017, 09:51:41 AM »
Sealed the chain oiler with bolt and RTV. No more chain oiler  :)
Re: Cracked Case ?
« Reply #4 on: December 10, 2017, 10:42:21 AM »
Clean the with degreaser, take a photo and show here, maybe you'll get a good recommendation
Offline Dunk
Re: Cracked Case ?
« Reply #5 on: December 10, 2017, 01:58:35 PM »
If it's a crack that's weeping and not a gaping hole I'd probably go the clean thoroughly, rough it up, and JB weld route. You can do a proper repair or replace when it's a better time to go through the engine.
Re: Cracked Case ?
« Reply #6 on: December 10, 2017, 03:10:51 PM »
+1 on the JB Weld thing, has worked for me in the past, you just have to get the area really clean and, yeah rough it up too
Offline rddcw
Re: Cracked Case ?
« Reply #7 on: December 10, 2017, 04:55:55 PM »
I appreciate all the "Good" recommendations  :) and was thinking about JB Weld.  Is there a certain type for aluminum pair ?
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: Cracked Case ?
« Reply #8 on: December 10, 2017, 05:26:43 PM »
There is Marine JB weld also another type Mastercool 90935?? A.C. repair epoxy, both available online if you search for it.
Charlie
Sent from my SAMSUNG-SM-G925A using Tapatalk
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Re: Cracked Case ?
« Reply #9 on: December 10, 2017, 05:44:25 PM »
 I think you will be fine with just the old fashioned regular slow drying two part JB that's been around forever that you can buy at any auto parts, hardware store or Wallyworld for that matter.
Offline Yamahawk
Re: Cracked Case ?
« Reply #10 on: December 10, 2017, 07:07:01 PM »
Found both those products at WallyWorld online lol...
Edmund Burke
Romans 8:28
Job 13:15
