Author Topic: Idle issue  (Read 1038 times)
Offline BlueRidgeHonda
Idle issue
« on: December 21, 2017, 07:20:57 PM »
Hey Guys,
I can't believe my build is so close to being finished! But I have just one more issue/question for ya'll.
When the bike is running, it's misfiring on cylinder number 1 when trying to idle.
At times it idles well, but then spits back through the number 1 carb.
I have:
-checked valve clearance and I'm fairly certain there is enough (.002in), even though I did not use a feeler gauge.
-replaced the #1 spark plug with a new one.
-briefly checked the pilot jet and seems to be clear. The carbs were cleaned last year and havent been installed until now.
The 1&4 ignition coil seems to be alright because #4 is firing just fine. Again, all of this is being tested in the shop and not after riding it on the open road.
I'm thinking it may be a valve seal issue or something in the carb itself? Just thought I'd ask the pros!
Thanks!!
Re: Idle issue
« Reply #1 on: December 21, 2017, 07:25:17 PM »
Oh, And the cam chain tensioner has been adjusted while at TDC.
Re: Idle issue
« Reply #2 on: December 21, 2017, 08:17:53 PM »
 What bike for starters. I would definitely use a feeler gauge to check the valves and the cam chain is not set at TDC at least for a 750 but the valve are .
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: Idle issue
« Reply #3 on: December 22, 2017, 03:30:59 AM »
I'm with ekpent, use a feeler gauge. You really can't 'check' valve clearance without one. .002" is a very small measurement, and you can't check that by 'feel'. Your cam chain has to be set ATDC, I believe about 14 degrees... you turn the crank past the 1-4T line, making sure that it is on the COMPRESSION stroke on the #1 cylinder, i.e. both valve rockers are loose... hence, checking the valve clearance first, setting it to your .002 or .003 intake clearance. The exhaust clearance is .003 or .004 btw. I am going to set mine to the looser setting of .003" intake and .004" exhaust, as I want to make sure it has adequate clearance as I am not sure if it has a performance cam yet. Hope you get it sorted, check for intake leaks on the #1 manifold also.
Charlie
« Last Edit: December 22, 2017, 03:51:06 AM by Yamahawk »
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline rotortiller
Re: Idle issue
« Reply #4 on: December 22, 2017, 03:49:00 AM »
Maybe richen up the idle circuit?
Offline DaveBarbier
Idle issue
« Reply #5 on: December 22, 2017, 04:39:47 AM »
You said you briefly checked the pilot jets in the carbs and that you're fairly certain the valve clearance is good. Be certain on these. Remove the carbs and remove the pilot jets and clean them perfectly once. Can't tell you how many posts people go back and forth in the carbs cleaning them because they weren't sure they were thorough enough the first time.
Also, check the spark plug cap resistance, might as well check all 4.
I'd also remove the spark plug on #1 after idling and see if it's wet with fuel or carbon fouled. I'd probably do this test first.
Edit: also what are your mixture screws set at?
