Thanks Frank and Joe, back in 1981 I cooked the engine's top end (a "mechanic" used silicon on a gasket and it clogged the oilways in the head) so I needed to rebore it for 4th oversize pistons, new cam and cam towers. The cam towers cost a fortune, as did the pistons and rings (I bored it myself on my cousin's old Repco boring bar) and I'd almost run out of money and couldn't afford the OEM cam, so bought the Andrews cam, which was half the price of the OEM item.
Looking at the Satanic Mechanic site I'm pretty sure it was the A grind cam, from memory it had a little more lift and duration than the stocker, and was a good torquey cam, if you don't want yours Frank, do you want to swap it for my 125/75?
Description and Application
A 20/40 .345 240 Good bottom end torque
40/20 .345 240
D 19/40 .385 244
40/19 .360 244
K 35/63 .370 278
63/35 .370 278
4 32/68 .400 280
68/32 .400 280
