Author Topic: newbie question (Fuel leak)  (Read 1710 times)
birdie
« on: June 04, 2005, 12:29:19 PM »
Hey,
    I've a 73 cb500f and my problem is that i constantly have fuel leaking out of the bottom thru a fuel line (overflow / drain?).  Like my subject heading says "newbie question" so please understand where I'm coming from!!  Thanks for any help.
Offline Dennis
Re: newbie question (Fuel leak)
« Reply #1 on: June 04, 2005, 12:44:33 PM »
Is this with the engine running or after it is shut off and left with the fuel petcock turned on?
Do a search of the website.
Very common problem. And a very common newbie question.
No point in my repeating it all here since I'm a terrible typist and it would take me an hour to type.
I hope that you have either purchased or downloaded a repair manual, you're going to need it!
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: June 04, 2005, 01:08:32 PM »
Yep.  You've got float valve problems, probably due to gunk from the tank.
Search on "float valve" etc and read the FAQs about cleaning carbs.
Moved from Non-SOHC (can't have fellow 500Fs in the non SOHC4 now can we ??)
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #3 on: June 04, 2005, 04:11:33 PM »
Another possibility is that the overflow standpipe in the carb bowl may have a crack in it.
Isolate which carb or carbs that are over flowing.
At the bottom of the bowl facing outward is a drain screw.  Put a shallow catch pan under it and remove the screw.  Examine the drainage.  If you can locate particles bigger than .4mm or .016 inch then you have a fuel contamination problem.  These pieces can plug up jets as well as block the float valve from closing.
  To check for a cracked stand pipe, you'll have to remove the carb bowl.
Prepare to improve your manual dexterity.
Oh yeah, and read the FAQ.
Offline Harry
    • CB500F
« Reply #4 on: June 04, 2005, 04:14:43 PM »
Give your carbs a sharp rap with the handle of a heavy screwdriver to see if you can loosen things up in there.
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
Finbar20
« Reply #5 on: June 04, 2005, 08:34:39 PM »
What Harry said. My 350f was doing that, Played those bowls like a xylaphone. Narrowed it down to #4. Now I just play that one
birdie
« Reply #6 on: June 05, 2005, 10:02:11 PM »
Thanks for the replies... i'll let you know what it was after i tinker with it.
