Author Topic: Generator rotor puller?  (Read 1835 times)
Offline Cormz02
« on: December 29, 2017, 12:50:43 PM »
Hey guys.  I am trying to get into the lower end of the engine on my cb550 project and the Manuel calls for a generator rotor puller.  I do not mind spending the $10 on one but was just curious if there are any alternatives to buying the tool.
Thanks.
Re: Generator rotor puller?
« Reply #1 on: December 29, 2017, 01:00:35 PM »
just a plain bolt,i forget the size right now but someone will remember before I have time to go and measure it.
Offline REAPER
« Reply #2 on: December 29, 2017, 01:03:47 PM »
I just struggled with pulling the generator rotor off my CB550 Crank last week. I used a standard automotive pulley/fan puller and it took quite a bit of torque to get it to pull loose. (Note: I also put a the M10x1.0 bolt used to hold it in into the tapped hole in the crankshaft, but didn't thread it all the way down - the bold has a dimple in the center so your puller doesn't slip) I was trying to gently tap it also, but it really seemed like the best way was just to put a lot of ass into it. I marred the generator rotor a bit, but nothing that would throw it out of balance or complicate reassembly. My best advice to you is to be really patient with it.
Good Luck!
« Reply #3 on: December 29, 2017, 01:10:33 PM »
the bolt is 16x1.5
Offline scunny
  • don't call me expert
« Reply #4 on: December 29, 2017, 01:36:41 PM »
from memory, I used the rear axle bolt.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline DaveBarbier
« Reply #5 on: December 30, 2017, 08:58:40 AM »
Rear axle bolt from the 550 won't fit. Use a bolt like Dave describes. May require heat. Will require tightening it down and giving it a few good smacks.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #6 on: December 30, 2017, 09:09:43 AM »
the bolt is 16x1.5
by about 50mm long?
...hey scunny, that pedal bike that leaks oil... that's actually Guiness Extra Stout... it just LOOKS like oil ;)
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #7 on: December 30, 2017, 12:31:56 PM »
I use the factory tool, wil, post pic later.
 I would not want to hit a axle that hard. Cheap puller bolts are online.
« Last Edit: December 30, 2017, 12:38:41 PM by 754 »
Offline rddcw
« Reply #8 on: December 31, 2017, 07:55:07 AM »
Motion Pro " Flywheel Puller "  M16 x 1.5 R.H.  # 08-0027  $6.95
« Last Edit: December 31, 2017, 07:57:09 AM by rddcw »
Online Don R
« Reply #9 on: December 31, 2017, 08:05:13 AM »
A cheap bolt will mushroom on the end and eat threads coming back out.
Offline Cormz02
« Reply #10 on: December 31, 2017, 08:07:02 AM »
I ordered the motion pro flywheel puller.  Figured I should just do it right instead of trying to be cheap.
« Reply #11 on: December 31, 2017, 09:30:20 AM »
 What can be important is that the end of the bolt is squared off and fits the end of the crank nicely.
 I did mean cheap puller bolt vs off the shelf bolts that might not be squared off on the end.
 Should add I have seen quite a few that are quit stuck and need a lot of effort to get off.
Offline DaveBarbier
« Reply #12 on: January 01, 2018, 04:15:15 AM »
I'm unsure the grade of bolt I used but it worked fine and cost me about $1. It didn't have a totally flat surface. You guys are over thinking it.
Offline Yamahawk
« Reply #13 on: January 01, 2018, 07:13:20 AM »
...judicious 'taps' with a 16oz jeweler's micrometer (ball peen) and a slight retightening of the bolt will break the taper and pop it off, usually. You don't want to wail on the bolt, but a sharp 'tap' and tighten of the bolt works for me...repeat as necessary. A hardened or higher grade bolt will help, too.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #14 on: January 07, 2018, 01:50:48 AM »
yep bloody oath over thinking it,so much so I thought id over think it some more and produce a knock puller,knock it tight then knock it sideways,then knock it once more and they always let go!
Offline przjohn
« Reply #15 on: January 07, 2018, 07:10:04 AM »
I have the Motion Pro tool too, low cost enough compared to other specialty tools. As has been said tapping lightly will break the fit. The worst one I ever had was a 75 Norton that looked like it would never come off, but with patience, all of a sudden one of the taps popped it right off.
Online Don R
« Reply #16 on: January 07, 2018, 09:27:54 AM »
It is amazing how tight some of them are with just a taper fit, and on occasion you hear of one that spun and the owner can't get it to stay on.
Offline Cormz02
« Reply #17 on: January 17, 2018, 11:08:50 AM »
Hey guys so I finally had time to get it out and noticed some bad marks on the back.  Is this normal or something I caused? It came of pretty easy and I did not put much pressure on it at all.
« Reply #18 on: January 17, 2018, 11:49:58 AM »
Looks like gaps in the weld that holds it together....
Offline Yamahawk
« Reply #19 on: January 17, 2018, 04:23:40 PM »
It certainly looks like someone worked on it... Frank, I have heard of people machining the rotor to lighten it, do you think it was perhaps what they did? That is where the weld is, at least I think I see a heat mark from weld zone in the metal.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Cormz02
« Reply #20 on: January 17, 2018, 06:02:26 PM »
Either way, is this something I should be worried about?
Offline DaveBarbier
« Reply #21 on: January 18, 2018, 04:27:48 AM »
Nah, unless you see big wear marks on the case for some reason. The rotor is nothing but a hunk of metal. Not really much can go wrong with it.
« Reply #22 on: January 18, 2018, 04:29:07 AM »
they often have those scattered weld holes in them.
Offline Cormz02
« Reply #23 on: January 18, 2018, 05:40:47 AM »
Sounds good thanks for the info
