Author Topic: Fitting Dyna 2000  (Read 1338 times)
Offline ttr400
    • ttr400 Projects and Billet parts.
Fitting Dyna 2000
« on: January 02, 2007, 11:16:24 PM »
Is the Dyna 2000, (the one that you can re-program) on the Dyna site able to fit the SOHC 750 motor or is this just for the DOHC models? I know MRiek has one on his 750. I have sent them an email but don't get a repy.
The reason I ask is I actually want to fit this to a CB400F. I do know the points plate is the same size 400 to 750 but I am not sure if the advancer mech is the same? although the dyna probably uses a new unit? Can anybody tell me if I could make the dyna 2000 work on my 400F.
I did a search and found previous topics on fitting to a SOHC but didn't find a conclusion.
Thanks in advance
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Re: Fitting Dyna 2000
« Reply #1 on: January 03, 2007, 04:14:48 AM »
Kevin
 Sorry, I must have missed that email ??? Anyway the 750 advance unit is removed for the 2000 as all curves are digital. I can post some pics of the mounted unit and give some measurements in a day or so.
  Mike
Offline ttr400
« Reply #2 on: January 03, 2007, 04:25:09 AM »
Thanks that will be a great help.
Sorry I meant I had sent Dyna an email
Kevin
www.ttr400.com
Offline ttr400
« Reply #3 on: January 05, 2007, 10:41:38 PM »
Mike I sent you a pm, let me know if you don't get it. not sure if I did it right.
Kevin
www.ttr400.com
