Author Topic: Leaky carb but NOT from overflow tube  (Read 1167 times)
Offline miketayc
« on: January 01, 2018, 12:24:01 PM »
Hey everyone,
I'm trying to locate the source of a gas leak from the carbs on my honda cb550. The tricky part is that is definitely not coming from the overflow tubes. It only occurs on the leftmost carb, and not while riding. It's a pretty slow leak and only occurs after the bike has been sitting for a while, like overnight. I was thinking the carb bowl might be loose or the gasket worn(but these are only a couple months old). But I don't think this can be the case because there is visible layer of gas above the float bowl too. pretty much half the carb will have this layer of gas above it I've attached an annotated picture for reference.
Offline miketayc
Re: Leaky carb but NOT from overflow tube
« Reply #1 on: January 01, 2018, 12:33:57 PM »
I was wondering if someone has seen such an issue before, or had any suggestions on how I might locate the source of the leak.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #2 on: January 01, 2018, 01:24:45 PM »
maybe clean it then powder it up with talc and come back a few hours later?
cb750 k6 - ugly
Offline kerryb
  • Not a very
« Reply #3 on: January 01, 2018, 03:16:55 PM »
Have you ruled out a leaky gas tank or petcock?
Offline eigenvector
« Reply #4 on: January 01, 2018, 05:19:26 PM »
Would you mind restating your last sentence?  I'm afraid I got really confused by what you were describing.  "visible layer of gas above it"
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #5 on: January 01, 2018, 07:08:23 PM »
I would check the float height and the gasket.
Offline Mr. Mike
« Reply #6 on: January 01, 2018, 07:32:07 PM »
Maybe park it, fuel valve off of course, drain the #4 bowl and check it in the morning. Touch the bottom of the bowl drain screw in the AM to see that it is also dry. If wet still, get your LED flashlight and a mirror to peer at the undersides.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline Airborne 82nd
« Reply #7 on: January 02, 2018, 01:54:12 AM »
Do you mean #1 ???
Hey everyone,
Offline greenjeans
  • 1972 CB750K2
« Reply #8 on: January 02, 2018, 08:13:28 AM »
Do you park your bike on the kick stand or engine stand?   If you leave it on the kick stand, some of the gas left in the carbs will run down to the left carb since it is the lowest point.  The bowl will then fill to a point that is just over the seal.  If the seals aren't great, you will get a little seep if it sits.
I'd also do a "clear tube" method to double check the actual level of gas in the bowl.  It's possible that that particular bowl fills a bit higher than the rest as well.
You could also just run the gas out, or drain it from the fuel bowls if you are going to park it for an extended time.  Ethanol sucks if you leave it sit for long periods.
* the photo posted is the right carb (as you sit on the bike)  Is that the one that leaks or is it the other side ?   If that is the one, disregard what I said earlier and double check the actual fuel levels with the "clear tube" method, and/or get new gaskets.
« Last Edit: January 02, 2018, 08:15:33 AM by greenjeans »
Offline Mr. Mike
« Reply #9 on: January 03, 2018, 08:28:29 PM »
“Leftmost” -I suppose so, I just focused on the pic...rightmost.
But either way....
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline jc914
  • 1974 CB550 "In progress"
« Reply #10 on: January 18, 2018, 10:19:24 AM »
I had a similar issue, it turned out the "O" rings in the "T" fitting between two carbs were old and needed replacing.
1974 CB550K0
