Author Topic: Greetings from another Toronto member  (Read 689 times)
Offline BigB
« on: January 03, 2018, 09:15:24 PM »
So the story goes ...
Been into bikes for 15 years, owned approx 12 in that time - some for riding, some for rebuilding. Along the way I purchased a 1982 cb650sc bike-in-a-box 6 years ago, rebuilt and sold it. Fast forward to last fall, the gentlemen is letting it go and gave me a call. I'm now the owner of my own rebuild, which is of course now scattered in parts across my back room - engine out, head off, pistons soaking in pin-sole - Ready for phase 3.
It started it's life as a cb650sc. Low compression & gumbed up carbs but was soon running like a champ. I picked up a tank & a few bits and turned it into a standard/custom. Hopefully the pics work.
This is pic is after being rebuilt as a nighthawk
650sc
Offline BigB
Re: Greetings from another Toronto member
« Reply #1 on: January 03, 2018, 09:16:41 PM »
Second pic as a standard/custom.
650sc
Offline BigB
« Reply #2 on: January 03, 2018, 09:17:52 PM »
And finally, the inspiration for the winter project.
650sc
Offline BigB
« Reply #3 on: January 03, 2018, 09:27:44 PM »
Of course with any new member, there's gotta be a question ....
Cyl #3 REALLY smokes (sitting on the bike, from the left, the cyl with the tach cable). It gets worse once warmed up. It's light grey so thinking oil. Compression was good - 120 all round. Carbs synced perfectly and ran like a champ. I was thinking oil ring, but once dismantled, all looks good, nothing sticking.
Any thoughts?
And thanks all. I've been running VFR's & big cruisers but find myself doing more local runs so thinking that a nice mild scrabbler/cafe would be a nice fit.
650sc
Offline calj737
  • I refuse...
« Reply #4 on: January 04, 2018, 04:31:58 AM »
Valve seal or seat? Have you done a leak-down test?
Offline BigB
« Reply #5 on: January 04, 2018, 11:05:05 AM »
No leak-down test as was planning on doing the valves anyway, but thanks, will do my own version of the same and see.
I was thinking that compression was consistent so was really expecting a failed oil ring.
Heads are off so I take some seafoam and let it sit in the cylinder head overnight; any leaks and there's your answer - at least that'd the concept.  Of course don't forget to screw in the plugs :).
650sc
Offline Can550
« Reply #6 on: January 07, 2018, 10:31:39 PM »
Welcome Big B, from GTA
