Author Topic: Was there a Light switch on the 1974 CB750?  (Read 2297 times)
Offline redbug2
« on: January 04, 2018, 01:58:38 PM »
Hello,
Working on a 1974 CB750.
Previous owner butchered the old switch harnesses in his attempt to put ape hangers on the bike. I'm trying to bring it back to stock but I don't see a headlight control switch on the right controls as shown in my clymer manual wiring diagram.
Maybe previous owner switch out the controls to a non-switch control?
I see the left side has a high low switch. Would that have an off position?
Also, a little confused about the turn signal indicator on the handlebars. I guess it grounds in the switch. Are there any pictures on the net of the wiring in the headlight?  I can't make sense of the clear and white female shielded blue and orange connectors.
Thanks in advance for any information.
Regards,
redbug2
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Was there a Light switch on the 1974 CB750?
« Reply #1 on: January 04, 2018, 03:52:35 PM »
i haven't verified that this is absolutely correct but here... https://www.cmsnl.com/classic-honda-fansite/honda_wiring_diagrams/CB750(K3-K7).jpg
cb750 k6 - ugly
« Reply #2 on: January 04, 2018, 04:18:13 PM »
Hello,
My K4 has an on/off headlight switch on the RH control.
« Reply #3 on: January 04, 2018, 04:59:47 PM »
Hello,
And a Hi-Lo switch on the left, correct?
That's the way my 74 Cb550 is, anyway.
Offline DV Red Herring
  • Army RETIRED
« Reply #4 on: January 04, 2018, 05:52:17 PM »
Hello,
This how my K4 is set up as well. The Hi/Lo is on the left side switch.
« Last Edit: January 04, 2018, 06:02:36 PM by DV 750 »
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #5 on: January 04, 2018, 06:39:56 PM »
Hello,
Regards,
redbug2
On my harness that I am using, it has the clear and white end covers in the headlight shell, on the orange and lt.blue wires(usually turn signal colors). I found these were not actually connected inside the wiring harness, as when I removed the wrapping on it, I found they were just laid in there, and were not actually connected to the harness. They must be extra wiring for some kind of option, like flashers, used on perhaps a Police bike or something, but weren't implemented on my harness. I believe my harness is a 1974 also, it came in a bin of parts, and I decided to use it. The starter safety module is connected by a red 6 pin connector on this harness also.
You do have other wires that are orange and lt.blue, use those for the turn signal wiring, and not the half white/clear wire ends. I am attaching a picture showing the wires in question, not hooked up.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
  • Army RETIRED
« Reply #6 on: January 04, 2018, 07:11:56 PM »
I used the extra blue and orange leads to trigger the turn signal indicator on the bar clamp.
Offline carnivorous chicken
« Reply #7 on: January 04, 2018, 07:14:23 PM »
Extra blue and orange could be for a deleted turn signal buzzer, although '74 is a bit early. And if I'm not mistaken, '75 was when Honda started deleting the off/on switch for headlights but some 75's have 'em, some don't. Again, IIRC...
Offline disco
« Reply #8 on: January 04, 2018, 07:30:17 PM »
I thought the extra orange/white & light blue/white were for the daytime ‘running lights’ that are used (or were used ?) on turn signals in USA?
I’m in Aus & we don’t use daytime running lights,so I just ignored those two wires in the repro harness, when I recently did mine. All works good for me.
« Last Edit: January 04, 2018, 07:32:31 PM by disco »
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline Yamahawk
« Reply #9 on: January 05, 2018, 02:42:14 AM »
Were they live or did you have to attach them? Mine were 'dead' as they had never been attached inside the harness. The lt.blue wire was folded in a hook shape, and the orange was straight, but never attached to the harness, as my picture shows. I may unwrap the harness again, and attach them to the turn signal wiring, in case i need more attachment points for the turn signal indicator also since I have the lights on the handlebar clamp too.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
  • Army RETIRED
« Reply #10 on: January 05, 2018, 09:07:05 AM »
Mine had been used previously, but at the time I got the bike the wiring was a rats nest. Using a wiring diagram I was able to get it all dialed in.
  • Army RETIRED
« Reply #11 on: January 05, 2018, 09:18:21 AM »
I'm not positive, but I think these bikes had parking lights? Maybe that explains why yours were unused? I do know that using the stock wiring harness I was able to attach front and rear turn signals and the indicator all inside the headlight bucket.
Offline redbug2
« Reply #12 on: January 05, 2018, 01:09:02 PM »
Thanks for the posts, they have been informative. I certainly have the wrong RH switch. The bike did have a rigged toggle switch in the headlight so I guess that's how the PO got around having the wrong switch.
Good to know that the two wires I've been scratching my head about are inert. Maybe I'll use the two female connectors in each as a coupling.
I'm going to tackle the turn signal indicator next. Since that light has an orange and blue wire going to it I assume its meant to take either right or left current and the switch will ground it. Orange on, blue is ground. Blue on, Orange is ground. ...?
Going to have another crack at it soon... Just having a cold snap here in Pennsylvania, -12 F  wind chill tomorrow. My barn is unheated and I can only take about an hour before my toes get cold!
Regards,
Redbug
Offline Yamahawk
« Reply #13 on: January 05, 2018, 01:51:27 PM »
I am thinking that the orange is left turn, light blue is right turn... green is ground. What part of PA are you from? My youngest daughter and her husband live just across the line in Sharpsville, Hermitage area. I also lived in Shrewsbury in York County, in H.S.
Charlie
« Last Edit: January 05, 2018, 01:56:11 PM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
« Reply #14 on: January 05, 2018, 02:35:36 PM »
The K4 has a park light, the tail light.
The ignition has 3 positions: 1.off 2.on 3. park.   I've never used it.
Of course we are talking stock here, who knows what has been changed on his bike over the years?
Offline redbug2
« Reply #15 on: January 05, 2018, 03:06:00 PM »
I'm in Southeastern PA. Pottstown.
Sorry if this is long, just thought I would share my findings for the Dash turn indicator.
Figured it out.... Here's my take on the situation. The front bulbs are double filament. They are passing current through both sets of Filament's. So, Positive going to light the bulb for one filament and I believe the other is used to pass ground back through.
Two wires into the front turn signals. Shell is ground.  For the Left front turn there is one black wire with a small blue plastic collar and another black wire with a blue collar plus a white collar.
Dash panel Turn signal indicator has orange and blue wires. No dedicated ground.
Coming out of the witch harness you have 4 wires that matter for the turn signals. Orange, Blue, Orange and white, blue and white.
I'll just comment on what happens on the left orange side, same setup for right, just blue.
I took the orange wire from the switch and put that in the orange multi female connector. Any black with orange collar also was plugged into the multi connector. I also took the dash indicator solid orange wire and put it into the orange multi connector.
I took the black wire from the turn signal with ORANGE AND WHITE collar and put that into the inert orange wire double coupler with the white and clear plastic shield. I then took the Orange with white strip wire from the switch and put it in the white and clear plastic shield.
For orange, when you turn the switch to the left it sends 12v down the orange wire energizing the signals (one filament on the front) and energizing the orange dash indicator wire. At the same time the switch then also grounds the blue wire with white strip which grounds the filament on the right turn sending ground into the blue multi coupler in turn sending ground to the blue dash indicator wire......
I also found the original RH switch with headlight on/off. It's butchered. I may take the time to repair it or I may just put in a toggle switch.
Regards,
redbug
Offline Yamahawk
« Reply #16 on: January 05, 2018, 05:44:53 PM »
Hmmm.... so the Orange/White/Clear and lt.blue/White/Clear shielded bullet female connector wires are just used as a hub connector for the extra wires to the dash light?It might be why they just terminate in the harness without being hooked up to the harness...
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Yamahawk
« Reply #17 on: January 05, 2018, 05:53:48 PM »
Edmund Burke
Romans 8:28
Job 13:15
« Reply #18 on: January 05, 2018, 06:09:09 PM »
Charlie
The Org/wht and lt. Blue/white wires are power routing for the running/ position lights filaments, sourced at the bar switch.   The dash turn indicator gets a connection to the org and lt blue wires.  It will illuminate when either the right or left signal lamp is lit because the switch grounds the not lit signal lamp.  Ergo the indicator blinks with whatever signal is blinking.
When the bright signal filament is lit, the dim run filament is unpowered.  This is so it will flash bright to dark instead of bright to dim.
This is how the stock left hand bar switch controls lighting.  Your link points to a right side bar control, which controls general lighting aside from the turn sigs.
« Reply #19 on: January 05, 2018, 06:58:48 PM »
I think in 75 lights on became mandatory.. 74 as far as I know, last year of the switch..
Offline Yamahawk
« Reply #20 on: January 06, 2018, 03:40:58 AM »
Charlie
Yep, thats good to know, but the wires I was referring to and kinda confusingly, are the ones in the picture I posted, that have no connection down inside the harness. If you look at the pic, the ends are female double bullets, and have a half clear and half white covering on the double female bullet connectors. The lt.blue one is bent double at the harness end, about 1" and didn't connect to anything at that end, where the orange one with the clear/white cover at its female double bullet is straight and also didn't connect at its other end inside the harness... I thought that was peculiar.
As for the link it is because the OP has a butchered rt. hand switch, and I gave him a link to the one I ordered.
Charlie
« Last Edit: January 06, 2018, 05:07:31 AM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
Offline KeithB
« Reply #21 on: January 06, 2018, 06:50:27 AM »
Charlie
This is done by a "breaking" contact in the LH switch.
There are a pair of wires in that switch loom that go to the turn signal filaments and a different pair that go to the "running" light filaments.(front only)
When you switch on the signals, the contact to the "running" lights is broken.
It makes for more wiring and the signals will work just fine without the "running" lights. (not parking lights!)
It's always easier to have an electrical schematic to work from.
Nanahan Man
Offline mrbreeze
  • Not your average
« Reply #22 on: February 10, 2018, 09:20:08 AM »
I'm in the process of putting my bike back together and having trouble understanding how the wiring for the turn signals works. I have all my signals working but the indicator only works on the left side. I had it working before but I don't recall what I did to do it. I recall having to jump something. I'm not running my front markers so the blue and orange with white stripes aren't being used. I have aftermarket signals front and back. The fronts don't have the grounding rings in the bucket. the ground wires on each side run to one of the ground buses on the main harness. I am having a hell of a time trying to get my brain around how the indicator bulb switches to ground the circuit when going to right turn position. Do I need to do something with those wires with the white stripes? My bike is a 1975 USA 750K with a born on date of 9-74 and has the headlite on/off switch on the right control.
MEMBER # 257
Online Don R
« Reply #23 on: February 10, 2018, 10:49:33 AM »
 I go to old man Honda and print out the color wiring diagram on two sheets of paper, then tape them to a piece of cardboard so I can stand it up and refer to it while I work.
« Reply #24 on: February 10, 2018, 11:15:44 AM »
The post-1973 CB750 lacks an Off-On switch for the headlight. It is only Hi-Lo, with a START button that disconnects the headlight during electric start cycle.
