Author Topic: Carburator pulling  (Read 1042 times)
Offline eigenvector
Carburator pulling
« on: January 04, 2018, 07:20:55 PM »
One more time for the cheap seats!
On the 550, it's easier to pull the carbs if you remove the airbox boots first - right????
I seem to recall trying that once and had a heck of a time getting them back in later.  Now having suffered through the Nighthawk airbox boots, maybe it won't seem nearly as bad - if I recall my airbox boots are pretty pliable.
So one for the cheap seats - pull the airbox boots and it should be relatively simple to remove the carbs - right?
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Carburator pulling
« Reply #1 on: January 04, 2018, 07:22:04 PM »
yes
Offline eigenvector
« Reply #2 on: January 04, 2018, 07:25:08 PM »
Alright - I can give it a go.
Since I've sidelined the Nighthawk for now, I decided to take this time to rebuild the carbs on the 550 - ultrasonic them, adjust them, rebalance them, and see if I can't get those darn fuel valves to seal.  Plus tap the bowl screws on carb 4 since I stripped one of the bowl screws.
Rob
1977 CB550K
1983 VF750S Sabre
Offline eigenvector
« Reply #3 on: January 04, 2018, 07:27:28 PM »
Forgot to ask - are those airbox boots on 4into1 good quality?
My #3 airbox boot is torn at the carburetor - doubt it sealing well.  Might as well pick up a new set while I'm doing this.
Edit:
Nevermind - 4into1 doesn't sell air box boots that will fit a 77 550k.  Guess I'll just repair them then. :'(
« Last Edit: January 04, 2018, 07:38:16 PM by eigenvector »
Rob
1977 CB550K
1983 VF750S Sabre
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
« Reply #4 on: January 04, 2018, 07:28:55 PM »
Yes on the airboots for both on/off of the 550 carb rack. Be sure to inspect the boots too though because over time the rubber wears and some opening may develop and you may need to patch the boots with some good bond. I found this material to work quite well
You can chase the mend with some Permatex Ultra Black gasket maker 82180.
Good luck!
Strynboen on the forums has mentioned heating up the boots first before removal/installation with a blow dryer to make them softer which is a good idea too.
« Reply #5 on: January 05, 2018, 01:35:38 AM »
the airbox boots should be soft and pliable,they are on the cold side,the manifold rubbers/boots are subject to extreme heat and are made from very heavy duty rubber/concrete?they can be boiled or heated to make installation easier,ive always boiled them then act quickly.
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
« Reply #6 on: January 05, 2018, 02:07:19 AM »
Concrete boots Dave?  ;D ;D   The Mafiosi will like you!!
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #7 on: January 05, 2018, 02:11:57 AM »
in my best new York/joisey accent,   I dunno what ya talking about?i dunno nuttin!cement shoes?who da hell ever taught they would be be comfortable?how da hell would I know about dat kinda ting?ya talking to the wrong guy already!
