Author Topic: Machinist question  (Read 955 times)
Offline greenjeans
  • 1972 CB750K2
Machinist question
« on: January 07, 2018, 01:50:54 PM »
Working on a silly XR600 project and I'm swapping the front end out for some USD Showas.  Anyway, I have to machine a bushing to fit in the upper triple as the hole in the triple is too big to use with the stem I'm swapping out.  I can make a bushing.
Most things I've read call for a steel bushing to be pressed in.  I know the ID that it needs to be.  Here's the question:  How much would you oversize/interference the bushing to press into the aluminum stem?
Offline J-Rod10
Re: Machinist question
« Reply #1 on: January 07, 2018, 02:26:05 PM »
.001" oversize per inch of hole diameter is the general rule for a press fit.
More importantly, before getting to that, is the hole actually round?
« Last Edit: January 07, 2018, 02:31:57 PM by J-Rod10 »
« Reply #2 on: January 07, 2018, 05:10:36 PM »
Is it a solid hole or has a split for clamping ?
 A thou should be fine, or size for size plus loctite... I would use aluminum.
If you need any shims under that, make a flanged bushing .
Offline J-Rod10
« Reply #3 on: January 07, 2018, 05:21:24 PM »
I googled it when I read it. Solid hole, just a small counterbore for the nut to sit.
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: January 07, 2018, 07:58:04 PM »
It's for the top clamp. Not quite as crucial as the bottom triple - that has the stem pressed in.  The XR head stock is a smaller diameter than the crf, so the stem is smaller diameter and has smaller diameter bearings.
.001" it is.  Hopefully, it's round enough.
« Last Edit: January 07, 2018, 08:02:11 PM by greenjeans »
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #5 on: January 08, 2018, 05:17:39 AM »
I wouldn't even press it in. Make a bronze bushing and slit it if the top clamp has a "clamp fit" for the stem. If the bearing is smaller, how does it fit the neck?
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: January 08, 2018, 07:56:53 AM »
I purchased a stem made to fit the CRF lower clamp.  It still uses stock size bearings.  Just needs a bushing to put in the top triple to make it work.
