Author Topic: spark plug wires  (Read 11078 times)
jakethesnake
spark plug wires
« on: January 03, 2007, 02:47:45 PM »
I recently purchased a 75 CB 750 and I need to replace the spark plug wires because they are all mangled and destroyed at the lower ends.  However, they seem to be run right into the coils with no connectors.  Is there any way to get them off or will I have to replace the coil and spark plugs together? I'd rather not replace the coil if I can avoid it.  Thanks
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: spark plug wires
« Reply #1 on: January 03, 2007, 03:01:14 PM »
this is a dilemma I have at moment with my coils.
I intend at some time to repair by cutting off HT leads flush with coil, push in a Brass pin and attach new HT lead to exposed part of pin, then seal with an epoxy resin.
You could also use a Silicon Sealer, just thought the epoxy resin would offer more support.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
jakethesnake
« Reply #2 on: January 03, 2007, 03:07:58 PM »
would that weaken the spark or anything?
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #3 on: January 03, 2007, 03:19:34 PM »
shouldn't do, use the same length and type of HT lead, the brass pin should not cause a high resistance or corrode unduly. There is a thread somewhere on here about similar repairs.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #4 on: January 03, 2007, 03:22:08 PM »
http://forums.sohc4.net/index.php?topic=10429.0 try this link
incidentaly, welcome to you jakethesnake, these appear to be your first posts.
« Last Edit: March 16, 2011, 04:28:06 AM by Glenn Stauffer »
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
jakethesnake
« Reply #5 on: January 03, 2007, 03:38:01 PM »
haha. how could you tell? thanks, i'll try to keep the stupid questions to a minimum
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #6 on: January 03, 2007, 03:44:10 PM »
No such thing as a stupid question on this forum. Some of the answers we give might be a bit questionable, though!!
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
jakethesnake
« Reply #7 on: January 03, 2007, 03:51:06 PM »
so is that the only advisable answer to my question? i'm not sure i trust my epoxy resin skills that much...
Offline jtb
  • An unlikely
« Reply #8 on: January 03, 2007, 05:01:05 PM »
Jake,  Check Parts N More, I think they carry an NGK splicer.
John
1977 CB750F
1985 V65 Sabre
Offline jtb
  • An unlikely
« Reply #9 on: January 03, 2007, 05:01:43 PM »
By the way, what kind of snake? ;D ;D ;D
1977 CB750F
1985 V65 Sabre
Offline jabbadeznuts
« Reply #10 on: January 03, 2007, 06:03:32 PM »
 :D :D I dunno about stupid questions. I remember a thread of mine that was rather stupid.
Jake - welcome
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #11 on: January 03, 2007, 06:38:23 PM »
I got your wire splicer right here!
http://www.z1enterprises.com/detail.aspx?ID=1890
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline jtb
  • An unlikely
« Reply #12 on: January 03, 2007, 08:11:19 PM »
1977 CB750F
1985 V65 Sabre
Offline 750goes
  • it will live
« Reply #13 on: January 04, 2007, 01:09:38 AM »
Jabba,
everyone loves you man,,, you will forever be in my "best of" moments,,, you got the nuts dude.... :D
Offline Jonesy
  • Shop Rat
« Reply #14 on: January 04, 2007, 03:45:40 AM »
I've used those wire splicers from Z1. Great success.
Offline hcritz
« Reply #15 on: January 04, 2007, 07:25:06 AM »
Hey Snake...
I wrote up a how to on replacing the wires about 6 months ago...with some picts...so far it's worked great...I've put about 5,000 miles on them so far.
Takes about an hour or so and some simple surgery of the coils...
Can't remember the thread...but you should be able to search for it...
jakethesnake
« Reply #16 on: January 04, 2007, 08:26:14 AM »
so how exactly does it work? or is it pretty self explanatory once i get it?
Offline hcritz
« Reply #17 on: January 04, 2007, 08:28:51 AM »
Should be...I used a dremel tool and cutoff wheel and cut the plastic of the coil at the wires...Soldered new ones in and filled the cut out area with epoxy....
Brand new wires all the way to the coil...
I'll see if I can find the like to the post.
Offline hcritz
« Reply #18 on: January 04, 2007, 08:36:53 AM »
Hey Jake...
Here is the link...
I had a hard time getting the picts small enough to post...most of the info is on page 2 and there is a link to the picts...hope they are still there...
I "MAY" still have the doc. somewhere on my computer if the picts are gone.
« Last Edit: March 16, 2011, 04:29:55 AM by Glenn Stauffer »
Offline DrMark
« Reply #19 on: January 04, 2007, 08:40:24 AM »
Another option is replace the coils with a set for an early 1980's CB900. I believe mine were from a 1981 model. Many of our members here have done the same upgrade. I found a set on ebay for less than $15. These will give you a hotter spark, allows the option of changing the wires (as the wires are not permanently attached). On my 1978 CB550K, I only had to reverse the mounting bracket...no other mods needed. Down side is a hotter sparks may burn out the points sooner than the original coil might. It changes it from a 5 ohm to a 3.3 ohm. I did mine over 2 yrs ago and have not had a problem yet.
Later, if you want to upgrade to an electronic ignition....these coils will handle that fine. Hope this adds some insight. DrMark
1978 CB550K
1983 CB650SC Nighthawk
Offline cadler
« Reply #20 on: January 04, 2007, 09:57:35 AM »
i just pulled the old ones out and twisted new ones into the coil and to the spark plug caps.
make sure you get solid core wire.
Offline dusterdude
« Reply #21 on: January 04, 2007, 10:27:25 AM »
my local honda dealer sells the ngk splicers too.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
jakethesnake
« Reply #22 on: January 04, 2007, 01:04:45 PM »
how do i use the ngk splicer? does it splice it to part of the old lead or directly to the coil because one of the old leads is also pretty mangled where it goes into the coil so i can't splice the two leads together
Offline Rsnip988
« Reply #23 on: January 06, 2007, 02:46:56 AM »
NGK 7mm Sparkplug Cable Splicer
Description:  For those using a sealed CDI system, NGK has developed a water resistant cable splicer to connect NGK Racing Cables to the stock ignition system. Simply insert each cable into the splicer, tighten, and you are ready to go. When used in conjunction with the NGK Cable Splicer, NGK Racing Cables can save you the significant expense of replacing entire ignition systems simply because of a failed cable.
worked for me but i cut mine off out from the coil, not directly off of it so I'm not sure, i think you can get the coil open and rewire a new wire to it, at least i think i read about doing that somewhere
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #24 on: January 06, 2007, 04:34:19 PM »
Yeah, what he said! lol  I picked up coils that I think were from a Honda NightHawk, originally? They have like an NGK splicer thingy built into the ends of the coils for wire replacement. (see picture)
« Last Edit: January 06, 2007, 04:36:32 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
