Author Topic: Throttle tube cover  (Read 1290 times)
Offline GardenGnome
  • 1977 CB550F
Throttle tube cover
« on: January 21, 2018, 02:05:25 PM »
 I doubt this will gather much attention but I am having trouble finding what I need.
I purchased an OEM style throttle tube for my rebuild. I am ditching the OEM controls and going with the M-Switches and M-Blaze turn signals. Is there a part that I can purchase to cover the push pull ends of the throttle tube?
I did notice that Biltwell makes a really nice throttle tube, but it looks as if the ends wouldn't allow for the M-Blaze turn signal to be installed.
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Throttle tube cover
« Reply #1 on: January 22, 2018, 07:57:56 AM »
gg, wouldn't you need some sort of minimalist throttle cable assembly like this?  https://i.pinimg.com/originals/e8/12/77/e8127760c9ab2ce041106f62fa2fc8e5.jpg
cb750 k6 - ugly
Offline GardenGnome
  • 1977 CB550F
« Reply #2 on: January 23, 2018, 09:19:26 PM »
Yeah most likely. To be honest though, I have no clue what I'm doing. But that setup looks perfect, easy and minimalist. I've been in contact with a rep from Biltwell, and their 7/8 whiskey throttle tube seems like it will work. It's all inclusive, but a bit more bulky than the image you posted. Still I think it will work. Thanks for posting the image. If it's not too much to ask, where did you find that picture?
Offline PGF550F
« Reply #3 on: January 25, 2018, 08:27:31 AM »
I used one of those on my 550 when the stock switchgear was trashed. Got it from dime city cycles. Pretty sure I remember it being EMGO brand when I opened it up. It was nice and thin and worked well. Drilled and tapped for stock Honda push/pull throttle cables.
https://www.dimecitycycles.com/satin-black-oem-style-single-dual-throttle-assembly-78-handlebars.html
Cheers
Offline evinrude7
  • not a kung-fu
« Reply #4 on: January 25, 2018, 04:58:20 PM »
i think the one in the photo is either the emgo or a domino.
cb750 k6 - ugly
