Author Topic: Mystery tank  (Read 984 times)
Offline gmog44
Mystery tank
« on: January 23, 2018, 10:54:16 PM »
My '72CB450 project's tank (left) was rusted out, so I found a replacement (right) on CL.  The 450-esque lines fooled me and I had it home before I realized it's massively wide.  Any guesses as to what this is?
'78 CB550
'72 CB450
Re: Mystery tank
« Reply #1 on: January 24, 2018, 06:13:10 AM »
Guessing.....some version of nighthawk or maybe cm
Offline calj737
  • I refuse...
Re: Mystery tank
« Reply #2 on: January 24, 2018, 06:30:00 AM »
Your original tank can probably be repaired. De-rust with any number of cheap, easy methods. Then, if there's hols you can have them brazed up, sheet metal replaced, or line the tank with POR-15 or Caswell. Maybe post some pictures of the rust damage for input?
Offline lowriderbud
Re: Mystery tank
« Reply #3 on: January 24, 2018, 07:43:36 AM »
The tank on the right sure looks like my tank which is off of a '72 CB750K.  Pictures of the front and back would help with the identification.  Also, which side is the pitcock on?
I would repair the original tank if it was my project.
Later, Bud...
Re: Mystery tank
« Reply #4 on: January 24, 2018, 10:35:15 AM »
Pic of underneath will explain a lot.
