Author Topic: Wheel offset?  (Read 1006 times)
Offline gmog44
Wheel offset?
« on: January 23, 2018, 11:02:24 PM »
Hi,
I've started a CB450 project, and the rear wheel is off-center by at least an inch.  Manuals and interwebs have not been helpful...  Can someone advise whether this image looks accurate?
Thanks in advance,
Garth
'78 CB550
'72 CB450
Offline calj737
  • I refuse...
Re: Wheel offset?
« Reply #1 on: January 24, 2018, 04:11:44 AM »
Looks like the wrong wheel spacers. Especially the right side one.
https://www.cmsnl.com/honda-cb450k7-1974-usa_model455/partslist/F++15.html#results
Offline lowriderbud
Re: Wheel offset?
« Reply #2 on: January 24, 2018, 07:56:31 AM »
The image does not look accurate.
Appears the chain is running at an angle.  You might have the spacers swapped, or as mentioned above the wrong spacers altogether. I would start by making sure the chain is tracking straight and smooth on the sprockets, determine what the length of the spacers should be for proper alignment.
Later, Bud...
Offline gmog44
Re: Wheel offset?
« Reply #3 on: January 26, 2018, 12:27:44 PM »
Thanks for the replies, and the link.  Since the whole rear end needs to be rebuilt, I'll look at simply replacing all of the spacers to make sure I have the right ones, check alignment, etc.  I appreciate the input!
Garth
'78 CB550
'72 CB450
