Author Topic: Flex or Ball hone for CB650 Top end Rebuild  (Read 4167 times)
Offline 81cb650
« on: January 24, 2018, 08:39:08 AM »
Hi All,
I've got a head gasket leak on my '81 CB650 and I'm getting ready to tear down and rebuild.  I have a claw shaped cylinder hone for 2-7 inch diameters, but I've heard flex and ball hones can be better for strictly breaking the glaze.  Does anyone know what size ball hone is best for the CB650 cylinders?
A link would be much appreciated,
Cheers
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=73lkh1i12ce02klnsj2lp4onc3&/topic,60973.0.html
Re: Flex or Ball hone for CB650 Top end Rebuild
« Reply #2 on: January 24, 2018, 09:19:34 AM »
the hone process vill after a short run Wear the old rings aut of spec...so new rings is a must.
.or leave it as it is no hone..if you not vant to thange them..
i hate all this v-w.... vords
« Reply #3 on: January 24, 2018, 12:11:21 PM »
I ordered my flex hones from here if I remember correctly. http://www.enginehones.com/fl2to2.html
For 65 and 67 mm bores. Brush need to have bigger diam than the bore to apply grinding force.
240 grit worked fine. Check ring status before by measure end gap. You need to take off rings from pistons for that, and on again which is a risk.
Tech info about it: http://www.enginehones.com/technical.html
Offline Yamahawk
« Reply #4 on: January 25, 2018, 02:41:02 AM »
Normally, the oversize is built into the hone, for the bore diameter ordered. So, if you have a 60mm bore, order a 60mm bore hone, it will already be a few mm oversize, according to the info at enginehones.com.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #5 on: January 25, 2018, 02:53:43 AM »
Yes, all bores have no perfect match of brush.
I used:
2 5/8" Flex-Hone® tool silicon carbide 240 grit (67mm) for 65mm bores. It did not feel like too big.
2 3/4" Flex-Hone tool silicon carbide 240 grit (70mm) for 67.5 mm bores
Stock CB750 need 64 mm brush since no 61mm brush
Remember that all tools are provided in over-sized, so do not add inches or mm's to the ID that you are machining.  If the bore size is between standard Flex-Hone® sizes, the next larger standard Flex-Hone should be selected.
Offline 81cb650
« Reply #6 on: May 17, 2018, 09:23:35 AM »
Thanks everyone
I went with: Performance Tool W80560 Piston Cylinder Hone 2"-7" 220 Grit
Seemed to work ok.  I did, of course, replace the rings.  Runs great, leaks like hell. I even doubled back and swapped the head gasket for a cometic, and it still leaks.  If anyone has suggestions for this let me know, it's driving me nuts.
« Reply #7 on: May 17, 2018, 11:30:08 AM »
torque, retorque...or torque, run bike and retorque.
shell out $$$ to have it decked, or $15 for some copper gasket spray
Offline Bankerdanny
  • Endeavor to persevere
« Reply #8 on: May 17, 2018, 12:59:39 PM »
If I can hijack this thread a little bit. A friend of mine at Moto Guild where I work on my bikes is finishing a rebuild of a KZ400. He did a full rebuild with new oversize pistons and a valve job including new guides. It would appear that the machine shop that did the work didn't check the jugs and head for flatness as he now has a pretty obvious leak. Per some advice I gave him he put in a couple heat cycles and re-torqued (he hasn't ridden it yet though, something I also advised him to do). He is now thinking he will pull the head and have it checked for flatness, it is possible that his issue could be addressed by pulling the head and applying copper spray to the existing gasket and reassembling?
« Last Edit: May 17, 2018, 02:01:02 PM by Bankerdanny »
« Reply #9 on: May 17, 2018, 01:40:14 PM »
That's a question I cannot answer, but from my F3 rebuild, the engine was apart and of unknown condition.
I didnt have the funds to have any machining done, but I prepped the surfaces as best I could, used HD studs, and copper-sprayed bottom and top end gaskets, and followed the torque/retorque sequence perfectly.
Thousands of miles and no leaks....
« Reply #10 on: May 18, 2018, 12:01:29 AM »
Some wet dry on a 1/4" plate glass on a flat table has been used by backyard rebuilders to check a surface for flatness...
You have to manually slide it over the glass with the sandpaper attached and it be wet and then by checking the surface you can see where it is taking down any high spots or if it is abrading the surface evenly. It won't work for big variations.
Better to have a machine shop measure and then skim off enough material to flatten the surfaces (both) and then you will have to check your clearances by that reduction to see if you will be looking at valve and pistons kissing one another which could require you to flycut the valve recesses in the pistons deeper.
Copper gaskets by Cometic are often used by racers and they often will weep and "leak" a little. Nearly impossible to use the copper gaskets without some leaking I am told.
David
« Reply #11 on: May 19, 2018, 02:57:06 AM »
ive never had these heads or blocks decked,ive drawn a file over them,if you deck the head and block or either you can run into cam chain tension problems,you might not be able to tighten it enough?a couple of heat cycles is better for retorque,just over night doesent really do much on a cold motor I think,means you gotta redo tappets etc but so be it.
« Last Edit: May 19, 2018, 03:00:17 AM by dave500 »
« Reply #12 on: May 19, 2018, 04:12:47 AM »
so long as the machinist whos never even seen one of these old bikes don't skim too much,just tell em to make it minimal at best.
Offline Bankerdanny
« Reply #13 on: May 21, 2018, 09:06:12 AM »
Fair enough Cal. But I would think that a good machine shop would ask if the customer also wanted the deck surfaces checked and if necessary explain the benefit that comes with the expense.
In talking with Dan about his 400, he said the machine shop never said anything about it one way or the other.
