Author Topic: Slide to bore distance in manual help  (Read 351 times)
Offline Doom64
« on: January 25, 2018, 02:24:10 PM »
Hello, I am doing a tune up on the cb400f and it says in the manual "check when the throttles are fully open,  the slide to bore distance is 0-1.0mm. Adjust using the full throttle opening screw.
What bit am I supposed to be measuring? And where is the full throttle opening screw?
I can't really tell what it is with the picture in the manual.
Thanks.
Re: Slide to bore distance in manual help
« Reply #1 on: January 25, 2018, 05:17:23 PM »
There is a hole the air goes thru into the motor. Is the slide clearing the hole or hanging down into it.
« Last Edit: January 25, 2018, 06:16:51 PM by 754 »
Offline Bodi
« Reply #2 on: January 25, 2018, 05:36:12 PM »
Look around the throttle wheel, there is a stop screw for full open. The slides should stick into the throat of the throttle that much, adjusted with that stop screw. The back side of the slide, not the cutaway edge.
I don't know offhand which screw it is, that should be obvious when you turn the wheel all the way open.
This isn't a super critical adjustment. Usually only needed if you completely disassemble the card rack and have to start from scratch with adjustment. There are several other adjustments needed if you've done that in order to get the idle screw and choke throttle advance working properly.
Offline Doom64
« Reply #3 on: January 26, 2018, 12:21:18 PM »
Thanks for the reply, found it, it was adjusted correctly already.
