Author Topic: Hydraulic Clutch  (Read 3798 times)
Offline DavHJ
  • Dave, Woonsocket, Rhode Island
Hydraulic Clutch
« on: January 27, 2018, 09:05:36 AM »
Looking to install a hydraulic clutch on my 1974 CB750K4 Resto-Mod, has anybody ever done it with any success? I know a new clutch cover will have to be made to mount the slave cylinder too and a new clutch rod. any info would be helpful.
Thanks,
Dave
1974 Honda CB750 K4 (owned since new)
1975 Honda GL1000 Gold Wing (all original with mechanical restoration)
2000 Harley Davidson Electra Glide Classic
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=eokuucs254nobrhdn6o4r6vvq1&/topic,60973.0.html
Re: Hydraulic Clutch
« Reply #1 on: January 27, 2018, 09:43:39 AM »
vhy..think the total set up vill be heavyer and bulkyer then the orginal set up....those vho does it on a 500 to get that spindel mekanism gone have a point..but the 750 have no big improvent ..just komplikation of a vell funktion system
on the 750 you can have the piston press/pull direkt inn to the clutch..so no need for the clutch rod..make a piston housing im aluminium and veld or bolt to the housing
« Last Edit: January 27, 2018, 09:46:25 AM by strynboen »
i hate all this v-w.... vords
« Reply #2 on: January 27, 2018, 11:37:03 AM »
Yes, it's been done and HOPEFULLY you can use the search to find it on here (which has worked sporadically recently).
Someone will probably chime in soon.
« Reply #3 on: January 27, 2018, 11:52:13 AM »
Thanks,
Dave
Dave,
Just curious? Why? Comfort (grip issues)?
« Reply #4 on: January 27, 2018, 12:14:47 PM »
The big brakes guy did a few, should be able to get it into the 750 cast clutch cover. Needs some milling, tapping not sure if he had to weld.
Found it but it did not take me right theorem here is the start point.
« Last Edit: January 27, 2018, 12:17:47 PM by 754 »
Offline Jore
« Reply #5 on: January 27, 2018, 02:13:11 PM »
I was thinking about this a couple of days back and stumbled upon this thing: https://www.ebay.com/itm/Motorcycle-Hydraulic-Clutch-Master-Cylinder-Rod-Brake-Pump-M10x1-25mm-Aluminum/401367953509?ssPageName=STRK%3AMEBIDX%3AIT&var=670990273303&_trksid=p2060353.m2749.l2649
You could probably have a workable hydraulic clutch using it.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #6 on: January 27, 2018, 02:36:33 PM »
That may be easier  my buddy had one on an XL 350. It worked, but I remember him saying he may change it, but I can't remember why.
« Reply #7 on: January 27, 2018, 06:16:10 PM »
yup, I rode an xr400 that had a similar set-up made by that Italian company that makes all the nice throttle housings, levers, and controls...worked very well and was small enough to possibly fit under the chrome cover of a cb750
Offline Remcod
« Reply #8 on: January 28, 2018, 12:02:13 AM »
Here is one for sale in the Netherlands based on a cbx750 clutch. Might give you some ideas
http://link.marktplaats.nl/m1247578203
Offline strynboen
« Reply #9 on: January 28, 2018, 05:06:55 AM »
there is no sence..in the half vay job..use vire pull to move the stock clutch rod..just as krazy as the BMW.. vire /to hyd marster under the tank.
..vhy make it all komplikated...and have the vorst from both systems..
a  hyd piston move direkt on the clutch..is the only logig vay..to make a better then stock ,and simpel system
« Last Edit: January 28, 2018, 05:08:29 AM by strynboen »
Offline DavHJ
« Reply #10 on: January 28, 2018, 08:05:19 AM »
That is definitely an option it just might work with the cable cover
Thanks,
Dave
Offline spotty
« Reply #11 on: January 28, 2018, 06:21:36 PM »
i'm assuming that thing works on a pull action rather than that pushrod pushing away from the body of the slave cylinder ? if it does it should
 be a possibility. it looks like those adjuster/locknuts would go nicely into the clutch cable hole in the honda clutch cover casing. might have to get one and see. i also, just by chance, have a spare clutch master cylinder cluttering up the shed.
i blame Terry
Offline spotty
« Reply #12 on: January 28, 2018, 08:48:39 PM »
and how do you bleed it? i don't see a bleed nipple
i blame Terry
Offline Jore
« Reply #13 on: January 28, 2018, 10:27:05 PM »
now that's a good question.
1975 CB400F owner
« Reply #14 on: January 28, 2018, 10:32:44 PM »
 Bleed it but loosening the banjo.
 My buddy changed it on the XL racers because of feel , on the start line it was digging in a bit and he felt it was too on/off.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #15 on: January 28, 2018, 11:42:39 PM »
The only reason I see to go hydro is if you're using really heavy springs and a very grabby clutch. The cable clutch works pretty damn good. Why fix what isn't broken?
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline spotty
« Reply #16 on: January 29, 2018, 03:25:36 AM »
Also to be had at your local bay of E are banjo bolts with a bleed nipple nestling within its bolty like end, plain steel, stainless or pretty anodised alloy
This conversion seems to be calling to me
And as for why....why not, nothing stock will be hurt and it can all be put back where it was and as I already have the m/c it'll cost me about $10. What could possibly go wrong
i blame Terry
« Reply #17 on: January 29, 2018, 08:58:21 AM »
That's why I asked.  I don't know much about the spec level of the engine and clutch on this build. Sometimes, the clutch pull on CBs is heavy for some riders.  I use a ball-bearing clutch lever to make the action smoother.
I had a hydro clutch on my RC51 -- smooth as silk.
