Author Topic: The nicest 35 mm trees for our bikes.  (Read 1576 times)
« on: February 03, 2018, 09:30:43 PM »
 Saw these last night, they are one of the nicest trees I have seen for 35 mm. Like Ceriani GP.
But.. except..
 These are11 mm wider...meaning you can run a wide rim and big brakes .
 I did manage  to mount a 6 piston caliper  and big floater on a set of GP,s, but its tricky.. won't work with most components
Offline slikwilli420
  • Master of Disaster
Re: The nicest 35 mm trees for our bikes.
« Reply #1 on: February 04, 2018, 04:54:07 AM »
I just ran across these. Gorgeous and I like the wider option.
« Reply #2 on: February 04, 2018, 02:50:46 PM »
That would seemingly avail you of more brake caliper options.  For instance, AP Classic line calipers are too wide and interfere with wheel spokes (without milling off material on the inner surface).  This would require some spacers, as well, for brake rotors but probably more options for different calipers and rotors.
Offline spotty
« Reply #3 on: February 04, 2018, 03:21:25 PM »
and where are you supposed to mount the apehangers?
i blame Terry
« Reply #4 on: February 04, 2018, 07:10:09 PM »
 The key turning point to me getting the 6 piston caliper to work.
 It was the discovery  that the Yamaha mag had the clearance that I needed. An 18minch front mag, not sure if that mattered. Stock spoke wheels, Morris mags are all thicker in the affected area. Fwiw.
Offline BLAC
  • An espresso is a
« Reply #5 on: February 05, 2018, 02:30:56 PM »
Clip-on ape hangers only  ;D
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline spotty
« Reply #6 on: February 05, 2018, 04:44:43 PM »
don't OCC do those for their cafe racer range
i blame Terry
