Author Topic: 1973 CB350f Leaky Carbs  (Read 982 times)
Offline zcb350fb
« on: February 05, 2018, 06:39:54 AM »
hey guys. the inner left carb on my 1973 cb350f was leaking. I took it a part for a rebuild. my question is, if you take a part one of the four carbs, do all of the carbs need to be synced again? also, if you take carb a part for cleaning, put everything back the way it was, do you need to re-set the float height or can you just put it back the way it was? thanks!
1973 cb350f
Offline robvangulik
  • Honda Fourever
Re: 1973 CB350f Leaky Carbs
« Reply #1 on: February 05, 2018, 10:09:45 AM »
What did you take apart? Just the float bowl and float valve, to clean it? Than you didn't change anything apart from removing dirt, and yo should be good......
Offline zcb350fb
« Reply #2 on: February 07, 2018, 06:31:04 PM »
Well I removed the needle, seat, float and float pin for a cleaning as well
1973 cb350f
