Author Topic: Front and Rear wheel bearings  (Read 1510 times)
Offline Bikebuff
« on: January 04, 2007, 07:59:04 AM »
Hi all,
Another question I have is who makes front and rear wheel bearings for a '70 K0?  I read on this forum that All Balls makes the tapered steering bearings, but didn't know if they also make the front and rear wheel bearings?  If they don't, who does?
Thanks!  :)
upperlake04
Re: Front and Rear wheel bearings
« Reply #1 on: January 04, 2007, 08:49:38 AM »
  If you have a bearing supply shop nearby, take your old ones in with you (or at least the part numbers) and they will match them for you.  I did this last winter for the bigger drive-side rear wheel bearing and was surprised the replacement was made by the same company, had same part number and looked identical to the 28 year old one - except the new one had seals on both sides. It cost less than $14.cdn including 13% tax. New bearings are a good deal.
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #2 on: January 04, 2007, 09:30:17 AM »
SKF makes nice ones....
« Last Edit: January 06, 2007, 07:51:36 AM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
