Author Topic: Ape 836 kit  (Read 1084 times)
Offline Hotwheelbill
Ape 836 kit
« on: February 06, 2018, 07:18:50 AM »
https://www.speedmotoco.com/product-p/ssr836.htm
I now have a set of APE Pro Street Rods and in looking for a 836 kit, I see this. Any thoughts or experience with this kit?
I love to make my bikes worthless due to high mileage!
2004 ST1300A .... the fast one. And dragging pegs on a CT.
1972…parts bike
1974…. Rusty frame but runs
1974 CB750..... Powder coated frame and parts, waiting for $$ hot rod motor.
1972 with 1975 old school drag motor
Re: Ape 836 kit
« Reply #1 on: February 06, 2018, 09:50:03 AM »
Looks like a great kit to me.
Offline Progas
Re: Ape 836 kit
« Reply #2 on: February 06, 2018, 10:55:28 AM »
You throw a Mike Rieck head on that kit and you would have a perfect set-up!!
Re: Ape 836 kit
« Reply #3 on: February 06, 2018, 02:42:45 PM »
Seems like for the price, it would take me a good bit of scrounging to do better.
I will have to call because there is another kit listed for $200 more but has the exact same description. Not sure of the difference
1972…parts bike
Re: Ape 836 kit
« Reply #4 on: February 07, 2018, 03:19:34 AM »
No ported head, why use a good kit like the APE kit or any other with similar components? Smaller chamber job and port clean-up as Hondaman recommends is much better than nothing.
Check options with MRieck.
Ported head is a mandatory part for me when upgrading the CB750 with higher CR pistons and cam. Most old heads out there need most likely a valve job recut seats and lap valves, maybe a few new guides too.
Lighten the alternator is another low cost upgrade.
Look for a used ported head.
My last K2 build got new stock size pistons and head with refurbished seats.
Re: Ape 836 kit
« Reply #5 on: February 07, 2018, 04:05:52 AM »
I do plan on some head work and bronze guides. Also plan on lightening the alternator and maybe the crank.
Not all going to come together this year, but maybe next.
1972…parts bike
Re: Ape 836 kit
« Reply #6 on: February 07, 2018, 09:32:30 AM »
My K head guides worked really fine with Honda steel guides. I think they last longer. A few replaced due to severe overheating with 2 pistons melting.
The head got bronze guides with kibblewhite 5mm valve stem kit. I should otherwise continue with stock steel guides.
Re: Ape 836 kit
« Reply #7 on: February 07, 2018, 08:43:50 PM »
 You can also get  the kit direct from APE. Looks the same to me and if you have questions they know the answers.
