Author Topic: CB750 mystery part found  (Read 4542 times)
Offline saltysultz
« on: February 06, 2018, 12:16:41 PM »
Hello,
I am rebuilding my 1977 cb750 motor and when i dropped the oil pan i found a mystery part seen in the picture. I figured i would crack the case and match it up to the cog or whatever it was missing from... no luck. Doesnt match any transmission or crank cogs. So my question is, does anyone know where this piece came from? It looks asymmetrical and almost like the last 1/2 inch of a claw from a hammer that broke off. Thanks for all the help!
Re: CB750 mystery part found
« Reply #1 on: February 06, 2018, 01:09:32 PM »
  These threads are always fun. Is it steel/magnetic ? Looks porous.
« Last Edit: February 06, 2018, 01:14:20 PM by ekpent »
« Reply #2 on: February 06, 2018, 01:43:33 PM »
Shift fork?
Offline mrbreeze
  • Not your average
« Reply #3 on: February 06, 2018, 01:48:18 PM »
Kinda looks like half of a woodruff key.
MEMBER # 257
Offline Swoop
« Reply #4 on: February 06, 2018, 01:50:42 PM »
It looks like it expired in Nonember 😎
« Reply #5 on: February 06, 2018, 02:26:29 PM »
For everyone except the thread starter!
« Reply #6 on: February 06, 2018, 02:51:16 PM »
tang end from kickstart mechanism?
Offline FuZZie
« Reply #7 on: February 06, 2018, 03:15:08 PM »
I had the exact thought until I enlarged the image.  :-[
Offline saltysultz
« Reply #8 on: February 06, 2018, 03:25:23 PM »
Woodruff keys aren't curved on both sides, correct? This one is curved on both sides. It looks too skinny and shiny to be a shift fork. going to take a look at the kickstart mechanism. it is attracted to magnets.
Offline my name is nobody
  • I like Pontiacs and Hondas
Offline przjohn
« Reply #10 on: February 06, 2018, 03:56:43 PM »
It looks to be anodized the same color as some Motion Pro brand tools, maybe a broken piece of a tool, gear holder?
Offline saltysultz
« Reply #11 on: February 06, 2018, 04:08:03 PM »
figured it out guys. my girlfriend who knows nothing about bikes or engines comes in and takes a look at the broken part and says "it looks like its from a wrench." It is an exact match to a 10mm open end wrench. I didn't break one but it has to be what it is. Thanks for all the help guys, sorry it wasn't a better answer.
Offline spotty
« Reply #12 on: February 06, 2018, 04:11:16 PM »
on vespas the flywheel is held in place by a woodruff key and so one day a friend of mine is trying to start his indian copy vespa when i noticed as he was kicking the flywheel wasn't turning in response to his ever more aggrieved efforts, pulled the flywheel and splinters of wood fell out of the woodruff keyway...ah those indians, environmentally conscious even back in the early 80s
i blame Terry
Offline setdog
« Reply #13 on: February 06, 2018, 05:16:10 PM »
ahem (cough) thats exactly what i was gonna say (cough)
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
« Reply #14 on: February 06, 2018, 05:37:51 PM »
hope you've eaten that bread its expired!
« Reply #15 on: February 06, 2018, 05:57:16 PM »
Wrench jaws aren't curved on both sides. How thick is it? Your picture angle makes it hard to get any sense of scale.
« Reply #16 on: February 06, 2018, 08:11:47 PM »
 If indeed it was a 10mm open end wrench tip it may have broken off while somebody was really reefing down hard on a cam sprocket bolt and it fell down the tunnel. Was there evidence that the engine had been opened up before ?
« Last Edit: February 06, 2018, 08:15:39 PM by ekpent »
Offline saltysultz
« Reply #17 on: February 07, 2018, 10:09:47 AM »
upon looking closer at it, it starts to curve at the end (broken end), same spot where the wrench jaw curves to go to the other side. The engine looks like it was taken apart before; looks like someone was messing with the valve train a bit and the cam sprocket, but didnt dig deeper. 10mm bolts are super common on it and i just bought the bike, so i'm just going to just pray that it's from a wrench. My girlfriend, who is way smarter than me apparently, pointed out it looks shinier than anything else in the engine and it does took like stainless steel.
Offline slikwilli420
  • Master of Disaster
« Reply #18 on: February 07, 2018, 10:30:09 AM »
Wrenches aren't stainless steel.
Offline DaveBarbier
« Reply #19 on: February 07, 2018, 12:40:13 PM »
+1
Looks chrome or satin chrome. But it does look in good shape meaning it wasn't thrown around by the chains or transmission.
Allow me to hypothesize. I wouldn't think I'd be able to break off a 10mm wrench on a small bolt that easily. I am weak though. Perhaps it was a cheap crow's foot on an extension? Doesn't really help to make up a story but it's fun and I'm off work today.
Offline przjohn
« Reply #20 on: February 07, 2018, 03:31:47 PM »
Is it just my picture or computer because it sure looks Blue to me?
Offline MoMo
  • Ride like you're invisible
« Reply #21 on: February 07, 2018, 03:42:19 PM »
Most likely be the sky reflection
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #22 on: February 07, 2018, 03:48:07 PM »
My first impression was a piece of an open end wrench as well. A couple of bolts that might snap a 10mm wrench could be the cam sprocket bolts or maybe the rocker arm adjuster lock nut.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #23 on: February 07, 2018, 03:53:09 PM »
You can see the grain structure of the metal, that is a fracture of a poorly heat treated piece of steel for sure. It may be a cheap wrench, as I have had one or two break while hammering... er... adjusting them with a 24oz micrometer...
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline DaveBarbier
« Reply #24 on: February 07, 2018, 04:36:08 PM »
Yeah, not blue. In shadows digital cameras tend to cool the entire image down.
