Author Topic: "Help Juntjoo fix his CB650!" thread  (Read 15779 times)
Offline Scott S
Re: "Help Juntjoo fix his CB650!" thread
« Reply #100 on: February 21, 2018, 04:33:13 PM »
 Wait a minute.... those carbs have a PUSH  and a PULL throttle cable. It looks like you have the choke attached where the push cable goes. I think.
 I've only had one CB650, so I'm no expert, but I don't *think* the choke cable goes there.
 EDIT:  watched the video again and I see that you have both throttle cables.
 It definitely looks like the choke is the culprit.
 If you pull the carbs again, can you install the cables without installing the carbs on the bike?
 I'd like to see the choke cable attachment and actuation. I'd like to see the gap on the butterflies from the bench sync at rest, too.
 Try attaching the cables and watch the choke operation before you install the carbs and see if you can find the culprit.
« Last Edit: February 21, 2018, 04:46:49 PM by Scott S »
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #101 on: February 21, 2018, 04:51:08 PM »
 Remind me again what part of Florida you're in?
'71 CB500 K0
'81 Yamaha XS650
Offline juntjoo
« Reply #102 on: February 21, 2018, 07:27:12 PM »
thanks. SWFL, Cape Coral.
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline Scott S
« Reply #103 on: February 22, 2018, 03:29:39 AM »
 Again.... I'm no 650 expert. I had those exact carbs only once. But I would think that the choke should only operate the choke and not the throttle. That last video looks better.... I think....
 I had a problem with the accelerator rod/diaphragm.  I had to find a replacement and cut the rod to the correct link. And this little low-speed injector "pipes" in the throats of the carbs are TINY. Took me several attempts to get them clear.
 The good news is, the 650 is a little hot-rod. If you persist, I think you'll be very happy with it.
 I ask your location because I'm a VJMC member and I might be able to find a fellow member that's local to you and willing to lend a hand, if needed.
 **Dang...looked back and, has it really been 5 years since I worked on that 650?! The 650 engine swap starts on page 4.
 http://forums.sohc4.net/index.php?topic=67907.75. **
« Last Edit: February 22, 2018, 03:37:33 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #104 on: February 22, 2018, 03:44:10 AM »
Yeah, I think Scott may be on to something, your throttle may not supposed to be opening when you use the choke. Its cable should be hooked to the enriching circuit, and not the throttle. Are your push/pull cables both installed on this bike? I have seen some where the PO removed the push cable from the throttle, and just used the pull cable. Check that your choke isn't hooked up wrong...really not sure if it would even work throttle-wise if your choke cable was hooked to the push side of the throttle linkage..
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline juntjoo
« Reply #105 on: February 22, 2018, 02:14:03 PM »
I thought we all had same carbs, either the pd or cv like mine. What do you guys have?
Can anyone with cv carbs, can you watch your throttle pulley while actuating your throttle to confirm it moves or not? I can't imagine what that little bendable lead arm is there for.
"Its cable should be hooked to the enriching circuit". Are you talking about the hole the throttle plates uncover with the  black idle adjustment knob or the holes for the pilot screws? I'm pretty sure this adjustment "fork" does something and it's only interacting with the choke shaft
« Last Edit: February 22, 2018, 03:13:41 PM by juntjoo »
-Ben
82 Nighthawk 650..
Offline Yamahawk
« Reply #106 on: February 25, 2018, 03:48:16 AM »
Yeah, the knob pulls a rod, which is linked to a fork that pivots and pulls a plunger on each carb. That is an enriching circuit. (choke) It is different than the manual chokes used on other carbs that physically close off the intake bell of the carb. It adds extra fuel by the enriching circuit, and that's where you get the higher rpm from.
Charlie
« Last Edit: February 25, 2018, 06:48:59 PM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
Offline juntjoo
« Reply #107 on: February 25, 2018, 06:20:49 PM »
Yeah, the know pulls a rod, which is linked to a fork that pivots and pulls a plunger on each carb. That is an enriching circuit. (choke) It is different than the manual chokes used on other carbs that physically close off the intake bell of the carb. It adds extra fuel by the enriching circuit, and that's where you get the higher rpm from.
Charlie
well I dont have this plunger you speak of, must the pd carbs, but okay, that hole my throttle plates  uncover would be this "enriching circuit".
-Ben
82 Nighthawk 650..
Offline Flyin900
« Reply #108 on: February 25, 2018, 09:28:36 PM »
There are a few holes in the carb venturi floor that you are referring to and yes that is part of the slow speed enricher circuit along with that brass tit in the floor of the venturi throat that is part of the accelerator pump circuit.
Did you verify you are getting a squirt of gas out of those brass nozzles in the front of each carb throat when you pump the bell crank after you cleaned and rebuilt them. This isn't part of your issue presently, yet will be a problem if those circuits are not all clear when you do get it running and ready to ride.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline juntjoo
« Reply #109 on: February 26, 2018, 03:19:45 AM »
yes thanks. just about everything engine/carb related has checked out as far as I can tell. Just on my brakes now so I should be off and riding soon
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #110 on: February 26, 2018, 05:34:57 PM »
does the path from the fuel tank petcock to the brass fuel tube over the carbs have to be slanted downwards to allow fuel to drop?
petcock to carburetors https://imgur.com/a/u2zvA
what I did to it was rebuild the petcock, and remove the vacuum operated one that no one likes, then connected a tube there but it's mostly horizontal and maybe a bit vertical before it curves downward onto the brass tube and Ive put a lot of fuel in the tank and confirmed it makes it to the bowl at the bottom of the petcock. So what could be blocking it's path beyond that bowl? Did that evil petpock I removed have a particular function that must be substituted somehow that I missed?
« Last Edit: February 26, 2018, 07:14:22 PM by juntjoo »
-Ben
82 Nighthawk 650..
