Author Topic: 1 hot cylinder  (Read 958 times)
Offline Dakotarider
1 hot cylinder
« on: February 08, 2018, 07:08:08 AM »
So I did my winter warm up last night for the 78 cb750.  Started right up and left it on 1/3 choke and went inside for a bit.  When I could hear that it was ready to idle down I went out and found cylinder 4 exhaust was glowing while the others were fine.  Is that because the bike was on kickstand and #4 was on the high side, therefore getting less oil?
thoughts?
It cooled down when I idled it down and went for a little spin, ran great.
If one bike is good, three is better!
Re: 1 hot cylinder
« Reply #1 on: February 08, 2018, 07:53:26 AM »
 If just one exhaust pipe was glowing and hot and the others were not she is trying to tell you something. Could be a carb problem,valve out of adjustment or something else going on in that cylinder bank. A good easy start would be to pull the spark plug and see what color it is and maybe compare to the #1.
Offline Bodi
Re: 1 hot cylinder
« Reply #2 on: February 08, 2018, 07:59:59 AM »
Not likely to be oil related. Possibly the #4 choke plate is not closing so it was running leaner than the other three? Hotter generally means leaner. The exhaust valve could also be sticking or adjusted a bit open allowing the burning charge to blow out to the header during power stroke?
Offline Dakotarider
Re: 1 hot cylinder
« Reply #3 on: February 08, 2018, 08:54:17 AM »
Hasn't been run in a few months, so I'm gonna start at the carbs to check out any blockages. Might try an additive first to see if it clears up.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: 1 hot cylinder
« Reply #4 on: February 08, 2018, 05:11:09 PM »
dakota, if you're not already doing so stick a fan in front of the fins while you're letting it warm up.
cb750 k6 - ugly
Offline Dakotarider
Re: 1 hot cylinder
« Reply #5 on: February 09, 2018, 12:40:46 PM »
good idea, that night I was warming it up outside, about 2 degrees F.
Offline evinrude7
  • not a kung-fu
Re: 1 hot cylinder
« Reply #6 on: February 09, 2018, 03:45:19 PM »
That helps keep it from overheating.
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
