Author Topic: CB750 Wet Sump Conversion - Sumpthing  (Read 114507 times)
Offline Bert Jan
    • sumpthing.
Re: CB750 Wet Sump Conversion - Sumpthing
« Reply #125 on: March 04, 2018, 12:55:12 AM »
The chopper guys would probably be glad to get their hands on one of these. No more hassles with locating the oil tank on the frame with extended lines. It would give a much cleaner look.
Stick with what you're doing. Sometimes this forum can be brutal when in my opinion its just not necessary.
Agreed👍
George
Thanks guys, appreciate it!
Offline kmb69
« Reply #126 on: March 04, 2018, 02:57:17 AM »
.....At this particular time, we're 2 kits short to order in a new batch. That's no marketing blabla, it's just how it is.
So if I order 2, how long to get them?
Offline Bert Jan
    • sumpthing.
« Reply #127 on: March 04, 2018, 04:21:16 AM »
The next batch will be here in about 2/3 weeks. Shipping to USA is anywhere between 6/12 working days. Thanks for your interest btw!
Offline Bert Jan
    • sumpthing.
« Reply #128 on: March 04, 2018, 04:23:30 AM »
We're also working on a USA dealersystem, so could be a bit cheaper (less shippingcosts) if you order from them later on. No idea how long this will take though
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #129 on: March 04, 2018, 06:45:02 AM »
Looks great! Guys, us chopper guys usually have ground clearance issues. How much lower do these hand below stock?
Offline gschuld
« Reply #130 on: March 04, 2018, 07:01:46 AM »
I believe the number is 50mm(1.96”)
George
« Last Edit: March 04, 2018, 07:12:02 AM by gschuld »
Offline voxonda
« Reply #131 on: March 04, 2018, 07:28:40 AM »
Correct George, 50 mm.
Offline gschuld
« Reply #132 on: March 04, 2018, 07:47:41 AM »
And FWIW, I just measured a few things down below the bike.  The lowest point on the kickstand bracket below the frame rails is 2”.  The bottom of the factory oil pan is almost perfectly even with the bottom of the frame rails, with the drain bolt hanging a further 1/4” or so.
So with the Sumpthing wet sump system mounted in a factory chassis, the bottom of the 2” lowered oil pan will be dead even with the lowest point of the kickstand bracket, with only the oil drain bolt dropping down a tad further.  The 1978 cb750f factory 4 into 1 header, for example, hangs lower than this.
George
« Last Edit: March 04, 2018, 08:58:35 AM by gschuld »
Offline voxonda
« Reply #133 on: March 04, 2018, 08:25:31 AM »
Think you mean side stand bracket, George?
Offline gschuld
« Reply #134 on: March 04, 2018, 08:59:43 AM »
Corrected above🙄.  Thanks Rob, my brain has questionable function after going to the gym.
George
Offline kmb69
« Reply #135 on: March 04, 2018, 09:14:05 AM »
Just placed an order for one.
Keith
Offline Bert Jan
    • sumpthing.
« Reply #136 on: March 04, 2018, 12:20:06 PM »
Keith
Order is received, thank you!
« Last Edit: March 05, 2018, 12:29:46 AM by Bert Jan »
Offline voxonda
« Reply #137 on: March 06, 2018, 01:57:18 AM »
While waiting for some oilpump parts, gaskets and bolts, I removed the oiltank and lines. Bike looks a lot lighter now........
Offline Tintop
« Reply #138 on: March 06, 2018, 04:46:04 AM »
It will be interesting to see how moving the weight of the oil & tank, and putting it under the engine changes the centre of gravity, and if that requires slight suspension setting changes.  Should put slightly more weight on the front end.  Following with interest Rob.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline voxonda
« Reply #139 on: March 06, 2018, 05:40:42 AM »
Hey Brian, thanks for your interest. Shifting weight up front and down low will change the C of G just very slightly and I do not expect to have to change my setup. Need to build new pipe because of the low sump, so maybe even have to raise the whole bike a little bit..........
Cheers Rob
Offline slikwilli420
  • Master of Disaster
« Reply #140 on: March 06, 2018, 05:46:52 AM »
How much does the kit weigh? My aluminum oil tank with all fittings weighs 42oz. I will have longer oil lines but that will add another pound at most. That thing looks pretty heavy.
Offline voxonda
« Reply #141 on: March 06, 2018, 06:00:54 AM »
This "thing" weighs 46oz.
Offline voxonda
« Reply #142 on: March 06, 2018, 06:11:53 AM »
I do cause of cooler, but no lines on streetbike, correct.
« Reply #143 on: March 06, 2018, 07:23:47 AM »
Ok so probably a 1lb savings over an aluminum oil tank. Not bad. Watching with interest.
Offline gschuld
« Reply #144 on: March 06, 2018, 09:23:36 AM »
For a rough visual, it’s roughly 8 pounds for oil tank/Sumpthing and oil.  Weight goes from the triangle to under the engine.  Not a massive shift in weight, but not insignificant either.
George
Offline dragracer
  • CB750F Dragbike
« Reply #145 on: March 06, 2018, 10:21:47 AM »
You'd be surprised how much difference it makes in moving that weight down low, and forward as far as drag racing is concerned.  Again, ground clearance would be my only concern.
Offline gschuld
« Reply #146 on: March 06, 2018, 12:17:19 PM »
The Sumpthing will be at the same level as the bottom of the kickstand bracket and be about 1/2” higher up than the bottom of the collector on your V&H sidewinder pipe.
George
Offline voxonda
« Reply #147 on: March 06, 2018, 12:33:41 PM »
Major set back......primary chains are out of spec. Damn......
Offline Bert Jan
    • sumpthing.
« Reply #148 on: March 06, 2018, 01:39:08 PM »
Ah #$%*.. You know what to do then...
« Reply #149 on: March 06, 2018, 07:10:09 PM »
Cheers Rob
If you raise the whole bike a little bit, it will more than offset the shift in C of G from removing the oil tank. ;)
