Author Topic: CB750 Wet Sump Conversion - Sumpthing  (Read 119245 times)
Offline Floshenbarnical
  • Money pit enjoyer
Re: CB750 Wet Sump Conversion - Sumpthing
« Reply #375 on: November 17, 2023, 07:34:33 AM »
Sorry for resurrecting this topic. I’m just trying to keep stuff as up-to-date as possible.
I’m currently (November 16/17/18 2023) running a Black Friday Discount on the kit.
I’ve reduced the price in the webshop so no need for fancy discount codes or anything.
Normal price is 499,- EU, now only 439,- EU which should basicly cover worldwide free shipping.
oi oi saveloy nice to see you posting here again, i just bought one as we discussed on insta.
Now I just have to figure out how to get an exhaust to fix around it. I was going to get a new one regardless because mine looks like #$%*, so it's just an extra step.
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
« Reply #376 on: November 17, 2023, 06:32:08 PM »
I think this is both a clever and well-designed conversion, if you want an oil-tank-less CB750. Takes some perseverance to assemble in the frame (for old guys like me), but it is made well. :)
  • Money pit enjoyer
« Reply #377 on: November 24, 2023, 06:48:15 AM »
I have to split the bottom end to solve a persistent oil seep so I was considering mounting it while the motor is upside-down on the bench, but I've seen that the motor is hard enough to get in and out of the frame already without a 50mm extension on the bottom.
Now I just have to convince someone to help me wrestle the bloody thing out of the frame.
'77 CB750 SS
« Reply #378 on: November 24, 2023, 06:28:13 PM »
I sure don't see a way around assembling the Sump Thing onto the engine after the engine is in the frame?
  • Money pit enjoyer
« Reply #379 on: November 29, 2023, 07:03:13 AM »
I think you're absolutely right. I had watched a video of a bloke installing it off the frame, but I think it was an instructional video for his channel and it was more convenient to film it w/ the engine out of the frame.
Do frame kits really make it much easier to get the engine in and out? Who has the best one? I know someone here on the forum sells them.
'77 CB750 SS
Offline newday777
« Reply #380 on: November 29, 2023, 08:31:51 AM »
Scottly was the last making the frame kits after Frank (754) passed 😢
I don't know if Scott has any kits left now.
Yes the kit will allow you to install the cases and sumpthing, then install the cylinders and head after when it is in the frame.
Stu
My current rides
Prior bikes....
  • Money pit enjoyer
« Reply #381 on: November 29, 2023, 08:46:55 AM »
I'm not splitting the cases. I was hoping the kit would make it easier to remove in one solid lump. I'm going to split the bottom end open so I can reseal it. I've got a very minor oil leak somewhere and I hate it.
'77 CB750 SS
Offline newday777
« Reply #382 on: November 29, 2023, 08:59:49 AM »
I didn't say splitting the cases.
It should give enough space for you to get the whole motor in with the sumpthing in.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #383 on: November 29, 2023, 11:55:22 AM »
I don't know this to be true. The Sumpthing is 5cm lower than stock. The frame kit allows just enough room to get the stock motor out. The extended oil pan still may not clear as the backbone is unmodified with a frame kit.
My suggestion is to plan to remove the Sumpthing each time and install it after the motor is in the frame. Order and have on hand extra oil seals. How many times do you plan to pull the motor after your "refurbishment" anyway?
You can already get the stock motor out without the frame kit. The frame kit allows the head and cylinders to come off in the frame so there is 5-6 inches extra space.
Stu
My current rides
Prior bikes....
  • Money pit enjoyer
« Reply #384 on: November 30, 2023, 05:31:05 AM »
Thanks for the responses everyone. I'm just going to install it while the motor is in the frame, once I've put it back in.
All I'm doing this season is trying to stop that oil leak. I'll probably throughly clean it and enamel it, but that's about it. I was going to have Hondaman take a look at the insides but I'm tight on cash so will try to get that done next year. But I will invest in some extra, good oil seals.
'77 CB750 SS
« Reply #385 on: December 06, 2023, 06:52:22 PM »
There's 2 places to check for that leak:
1. The countersprocket (chain) oiler adjuster's rubber inside the countershaft is probably a little shrunk from the years, now, so it is over-oiling. When I adjust them these days (if I don't replace the seal inside the shaft) I turn them in all the way to the stop, then backout 1/2 to 3/4 turn. Then it won't drip, and only oils above (roughly) 50 MPH, so keep an eye on the chain.
2. The Neutral Switch. Most of the bikes now have exceeded the 10-year-life epoxy used to seal the switch. While it can be re-sealed without too much work, you can also get a new one from Honda or (sometimes, they go quickly) at PartsNmore. It can just barely be installed with the engine in the frame. If you do this and need a new O-ring, PM me for one: it is size 3x18.
Offline Bert Jan
    • sumpthing.
« Reply #386 on: February 01, 2025, 12:12:58 AM »
Hi all,
Update about the SumpThing kit.
Production has been upped and we currently have around 20 kits in stock at any given time.
We’ve also managed to get a dealer/reseller in Ontario Canada, Sane Motion Moto. If you’re close to him it might be cheaper to get it from him.
We’re also actively searching for dealers/resellers for the USA (Preferably one west, one centre and one east) and other countries. Please don’t hessitate if you run a (web)shop and want to sell the kits!
Contact me at outsidersmotorcycles@gmail.com - MOQ for dealers is 10pc, color is up to you.
« Last Edit: February 01, 2025, 09:24:26 AM by Bert Jan »
Offline grcamna2
« Reply #387 on: February 01, 2025, 01:27:54 AM »
Excellent  :)
75' CB400F/'bunch o' parts'
« Reply #388 on: February 02, 2025, 10:52:43 AM »
Hi all,
That's a fine quality kit you've got going! For the show bikes I've built they have been popular and simple enough to install. I made a flat steel (1/4" thick) plate in the shape of the oil pan for protecting the engines (and frames) on the way in - it's a snug fit - and then installed the Sump Thing afterward, not hard to do. Your oil-level window is a nice touch, too. :)
Back in the 1970s someone was making a similar conversion to yours, but sans window. It was popular with chopper builders back then: they would drop in one of Russ Collins' 1000cc kits and then the tankless conversion, but it held so little oil then that they changed it every 1000 miles (2 quarts was all it held). Yours holds more than that, though, a good thing. AND it can be checked, a great improvement! :D
Offline Bert Jan
    • sumpthing.
« Reply #389 on: February 04, 2025, 12:28:49 AM »
Thanks man! Appreciate it! It’s good to hear that the install process goes smoothly.
Good info about the previous guy who made such a unit. Any more info on that?
Offline Oddjob
« Reply #390 on: February 04, 2025, 06:10:12 AM »
I am curious as to why a imperial 7/8" spanner was used in the video for tightening up the sight window, I'd have thought you would have been all metric by now, especially as you are in Europe, the home of metric. I doubt I have many imperial sizes left in my toolbox these days and I'm sure that's true of most others. Just wondering if the sight window is metric sized or imperial?
Love the kit BTW, extremely well made by the look of it.
Offline spotty
« Reply #391 on: February 04, 2025, 01:52:28 PM »
i gave away or threw out all my non metric stuff years ago, partly cos i don't need it cluttering up the place and partly so when my mates tell me to buy a harley i can truthfully say the only tools i've got that fit it are hammers
i blame Terry
« Reply #392 on: February 05, 2025, 05:35:02 PM »
He was a guy in California circa 1970 or so when I first heard about the kit. If I can somehow find the name again I'll post it up, but your parts are much better made. He didn't have the nice CNC equipment like you have, it was just made on a per-each basis, like so many other California Custom industries of the 70s were. They looked like the top and bottom were flat-ground on a Blanchard or maybe a surfacing table like for car engine heads, because the grain marks were still pretty deep. The instructions included using  Permatex#2 as the sealant on the gaskets, which is famous for its ability to stay flexible and endures hot oil well - but it is ugly when installed because it always blooms out of the joints when it heats up the first time and seals. If you then cut away the black ridge it makes, it will weep. Hondabond is better, but I don't think it is thick enough to seal those old machining marks: this is where yours excels - with nice gasket surfaces. :)
Offline Bert Jan
    • sumpthing.
« Reply #393 on: February 08, 2025, 12:24:24 PM »
Hey man, sharp eye! The video was uploaded by a US customer. I guess he didn’t have the right metric spanner. The sightglass is metric by the way. M16x1.5 threads. From memory, it’s a 22mm spanner.
Thanks for the kind words about the kit! Lots of work into it so always nice to read people’s positive response!
Offline Bert Jan
    • sumpthing.
« Reply #394 on: February 08, 2025, 12:24:59 PM »
Offline Bert Jan
    • sumpthing.
« Reply #395 on: February 08, 2025, 12:27:40 PM »
Would love to get more info or even pictures of such a thing. #$%*ing awesome somebody tried it before. Very curious how he managed to get oil re-routed to the gearbox without a cnc machine. Gave me some serious headaches haha
« Reply #396 on: February 08, 2025, 07:37:00 PM »
He never advertised except once that I saw in Choppers magazine. Where yours has the nice block for the oil pump to sit upon, his was a separate piece, very fiddly to install when laying halfway under the bike with oil dripping on the face. There were some (3) real long bolts to hold the pump and block up into the drive gear for the pump, and there was no screen on the bottom for the sump pickup part of it. After the pump went in there was a real hard-to-do task of fitting over-thick O-rings into the section where the oil hoses had to connect to the pump block (that's what I called it) with airtight connections, and this was the hard part of it, because the pan had to be installed at the same time with those O-rings: I greased them to stay in place because I kept knocking them off while trying to raise the pan up in between the frame, by Braille, because you couldn't see to do it. The oversized bolt holes tended to weep oil, so they (not mine) would get sealant pushed up inside of them, or in my case I added thin rubber washers and flat washers. In the end I didn't finish doing it myself as I had Finals Week at the college, and one of my shop mechanics got it working. He also told me not to offer to do another one, or else "you can do it yourself next time". Not a rave review?
The outer pan was nicely polished, though, which was mandatory for chopper parts in those days. :D
Offline spotty
« Reply #397 on: May 24, 2025, 10:02:55 PM »
Terry very kindly put me onto a FB ad for one up past Sydney somewhere, $700 inc post ( about $450ish US ) and hence another problem sorted on the chopper, I can get rid of the arse ugly oil tank and battery box, I'll replace it with an electrics tray mounted up flush under the seat with a small battery laid down on its back. As with the dirt bike it'll be kick only
i blame Terry
Offline grcamna2
« Reply #398 on: May 24, 2025, 11:22:50 PM »
Does a shop up past Sydney act as a dealer for the Sumpthing ?
Offline spotty
« Reply #399 on: May 28, 2025, 03:46:59 PM »
this one came from a private seller, never thought to ask him where he'd got it from
i blame Terry
