Author Topic: Ignition identity?  (Read 1535 times)
Offline medic09
Ignition identity?
« on: January 04, 2007, 12:00:24 PM »
A friend found this in a '84 Kawasaki KZ550 that he's rebuilding.  Their doesn't appear to be an advance mechanism.  Can anyone identify this ignition system and tell us about it?  Thanks!
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Jay B
Re: Ignition identity?
« Reply #1 on: January 05, 2007, 04:48:42 AM »
My son has a '82 KZ750 and that ignition doesn't look anything like his. The bolt and hex washer looks the same though, are you sure there isn't an advancer under that trigger plate?
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline medic09
« Reply #2 on: January 07, 2007, 08:25:16 PM »
I only had a chance to peek behind the trigger plate.  I couldn't make out an advancer; at least not that I could recognize.  All I could make out was the shaft behind the trigger plate.  By now Dave may have the thing out and figured it out, but I haven't heard any more about it.
No one going to be able to tell us about this ignition?
Mordechai
'78 CB750K
Santa Fe, NM
Offline 750goes
  • it will live
« Reply #3 on: January 07, 2007, 09:03:34 PM »
I think it's electronic -180 degrees between firings - equivalent to a Dyna ignition - set once and forget??
I'll show my ignorance and suggest that you set the ignition to "F"  on 1 & 4 on TDC, then when the bike is running you could check/adjust it using a strobe timing light to check it falls between the two timing marks for any advance or retard.
Offline medic09
« Reply #4 on: January 07, 2007, 10:11:27 PM »
I was guessing in that general direction, though I didn't know what to do with the marks on the plate.  Your theory sounds plausible.
Anyone else have any insight into this?
Thanks!
Mordechai
'78 CB750K
Santa Fe, NM
Offline medic09
« Reply #5 on: January 10, 2007, 01:39:05 PM »
So, friend Dave found the fiche for this.  This is the email he sent:
Hi Guy, Well I looked up the parts fitch on the bike, and that ing. system is box stock 1984 KZ550. It must have been one of the last ones made, they switched to that system from the mech. advance to electronic. The parts book shows that system sans advancer. So we move on to another fix. Thanks for your input, Dave
Guess that answers our question.  It wasn't even aftermarket.
Mordechai
'78 CB750K
Santa Fe, NM
