SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Wiring Issue
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Wiring Issue (Read 764 times)
JonathanHValencia
Enthusiast
Wiring Issue
on:
February 11, 2018, 11:35:44 PM »
I purchased a new top triple clamp from Cognito Moto which has the oil, neutral, high beam and turn signal indicators. I can’t figure out which one is my neutral switch wire. Can you all help. I attached a picture. I keep reading and seeing diagrams saying it’s light green and red. Can you circle or pin point which one it is?
Also, it’s a mess in this headlight. What do you guys recommend as far as installing wire. Just stick to the crimp male and female terminals?
Logged
dave500
Really Old Timer ...
WHAT?no gravy?
Re: Wiring Issue
Reply #1 on:
February 12, 2018, 12:31:16 AM »
use a test lamp on the ones it might be,confirm by selecting a gear and the light should go out.
Logged
strynboen
Old Timer
Re: Wiring Issue
Reply #2 on:
February 12, 2018, 02:36:08 AM »
you have a 74 cb 750?
Red/Green vire..is the one..(its not positive povered but groundet) in neutral)..and the bulb is positive hot..on the orginal set up...
Last Edit: February 12, 2018, 02:42:41 AM by strynboen
Logged
i hate all this v-w.... vords
calj737
I refuse...
Re: Wiring Issue
Reply #3 on:
February 12, 2018, 05:14:48 AM »
When I click on the picture, it rotates to an orientation with your thumb on the left. In that orientation, its the 3rd wire from the left, Green with a Red stripe, sitting directly under your thumb. Left-most is Brown/Red in the picture.
Logged
'74 550 Build
http://forums.sohc4.net/index.php?topic=126401.0
'73 500 Build
http://forums.sohc4.net/index.php?topic=132935.0
JonathanHValencia
Enthusiast
Re: Wiring Issue
Reply #4 on:
February 12, 2018, 07:34:01 AM »
Awesome. I was just confused because my diagram says light green and red, and that looks dark to me. Thank you very much. There are no more spots for that particular terminal left in my head light. Any suggestions ?
Logged
JonathanHValencia
Enthusiast
Re: Wiring Issue
Reply #5 on:
February 12, 2018, 07:35:17 AM »
So my new set up comes with a green wire and a black wire for neutral. I should plug the green wire into the red green neutral line, then the black wire with a spare black from the harness?
Logged
calj737
I refuse...
Re: Wiring Issue
Reply #6 on:
February 12, 2018, 09:38:16 AM »
Correct.
Logged
'74 550 Build
'73 500 Build
JonathanHValencia
Enthusiast
Re: Wiring Issue
Reply #7 on:
February 12, 2018, 10:37:06 PM »
Reached out to the manufacturer. The lines go as the typical stock lines do, but with a difference. This is what he said:
The oil and neutral are the only ones that are reversed. Meaning that the colored wire is wired to an auxiliary positive and the black wire goes to the switches that are ground.
Translation?!!
Logged
calj737
I refuse...
Re: Wiring Issue
Reply #8 on:
February 13, 2018, 04:16:37 AM »
They mean the instrument light for NEU (GREEN) goes to your stock BLACK (powered) and the instrument BLACK (GROUND) goes to your stock GREEN/RED.
The same reversal is true for OIL. Your stock harness BLUE/RED usually connects as a GROUND, but in this instrument it needs to connect to the BLACK and the BLUE (if that's what comes from the instrument) connects to your harness BLACK.
Shoot a picture of the wiring coming from your instrument lights for clarification.
Logged
'74 550 Build
'73 500 Build
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Wiring Issue
