Author Topic: Wacky directional signals  (Read 908 times)
Offline fredmalito4
« on: February 12, 2018, 07:39:41 AM »
 Here’s my next thing to fix on this bike. I think the directional signals are possessed. I have made wiring repairs so that all lights are functioning. All lamps are LED of the correct type, and the flasher has been replaced with an electronic unit suitable for LED. Directional signals did not work on this bike when I got them, due to broken wires, burnt out bulbs and a bad flasher
What I’ve got now is really odd. Flip the directional signal to the left and the rear light comes on, front flash element comes on, front running light goes off. It does not flash. Flip the switch to the right all the way, the buzzer squeals once,  and the lights do the same thing as they do on the left, and they do not flash. If you very gently slide the switch slightly back from it’s locked position, the right light will flash and function normally. This trick  does not work on the left side.
Considering the wiring harness is stock, clean, and lights are functioning, I don’t think this is a wiring issue. I’m going to unplug the buzzer just make sure it’s not  interfering in some way. Short of finding a new switch housing just to test, do you have any other suggestions?
Thanks, Fred.
Offline FuZZie
Re: Wacky directional signals
« Reply #1 on: February 12, 2018, 07:45:22 AM »
year and model?
Offline fredmalito4
« Reply #2 on: February 12, 2018, 07:49:54 AM »
Sorry, ‘78 CB750K
Offline FuZZie
« Reply #3 on: February 12, 2018, 08:04:39 AM »
Can you verify it has the correct gauges with separate right and left flasher lights?
Offline fredmalito4
« Reply #4 on: February 12, 2018, 08:46:13 AM »
I’m not sure if the guages are correct, but it does have left and right arrows.
Offline robvangulik
  • Honda Fourever
« Reply #5 on: February 12, 2018, 08:57:18 AM »
Unhook both the buzzer and the warning light on your dash, they give trouble combinated with LED's.
Sorry, just realize you said '78, with 2 dash lights that shouldn't be an issue :-[
« Last Edit: February 12, 2018, 09:01:32 AM by robvangulik »
Offline Flyin900
« Reply #6 on: February 12, 2018, 09:18:47 AM »
Verify every light has a good ground to the frame and the green ground wires in the connectors are clean both male and female. You may have issues with the LED conversion, yet bad grounds will show up as wonky things like you have described with alternate lights lighting etc.
Just went through the same thing on a CB400F with regular lights doing weird things and it was all in the grounds not being good from repaint/powder coating of parts. The headlight bucket bracket where the front signals are mounted is isolated from the frame with rubber mounts on the bracket.
« Last Edit: February 12, 2018, 09:21:43 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline FuZZie
« Reply #7 on: February 12, 2018, 09:36:50 AM »
That's good you shouldn't need a diode. Try a combo, robvangulik's  unplug buzzer (leave gauge lights connected for now)
and go over the wires like Flyin900 is suggesting.
http://manuals.sohc4.net/cb750k/technical_reference/WD750K8.jpg
EDIT:
also please note if the gauge blinkers are working
« Last Edit: February 12, 2018, 09:40:20 AM by FuZZie »
