Author Topic: CB350F project  (Read 2083 times)
Offline Mr.Toast
CB350F project
« on: February 12, 2018, 04:00:07 PM »
Hi everyone, my name is Chris, I’m very new to using forums. I’m starting a 350F project and I’ve never done this so I was Hoping you guys could give me some pointers as to where to start (much appreciated). You can see (if I attached the image properly) that the bike is barely a bike and in need of a lot of rust removal. I’ll post more details when I can.
Offline Mr.Toast
Re: CB350F project
« Reply #1 on: February 12, 2018, 04:13:45 PM »
Thank you so much  😁
Offline WhyNot2
  • I'm finally an
Re: CB350F project
« Reply #2 on: February 12, 2018, 04:15:00 PM »
Looks like you got more than one there.
Offline Mr.Toast
Re: CB350F project
« Reply #3 on: March 11, 2018, 08:11:27 PM »
I’ve finally been able to start working on the bike, not too much has happened. Adjusted tappets, removed some dirt and grime that, changed oil and removed carbs. I cleaned the carbs and when I did part of what I think Goes to the carb cane out. If anyone knows if it’s part of the carb or where it goes it’d be much appreciated.
Offline Remcod
Re: CB350F project
« Reply #4 on: March 12, 2018, 11:25:11 AM »
Its part of the linkset that was one piece but seems to have broken off. Number 8 in the partsmanual e-19 diagram
Offline Mr.Toast
Re: CB350F project
« Reply #5 on: March 12, 2018, 03:01:37 PM »
Thank you so much
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: CB350F project
« Reply #6 on: March 12, 2018, 04:04:56 PM »
Great to see a 350F get restored. Keep the photos coming.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: CB350F project
« Reply #7 on: March 12, 2018, 04:12:34 PM »
Get a small ultrasonic cleaner, take the carbs all the way down and clean them in a 50-50 mix of simple green and water. Be sure to keep the parts together as sets. There are other good cleaners too, I had great results with simple green. A stronger mix is not kind to the aluminum.
1973 CB 750 K3
Offline Mr.Toast
Re: CB350F project
« Reply #8 on: March 12, 2018, 04:50:54 PM »
 here’s a better look at the bike now
