Author Topic: Removing swing arm bolt....  (Read 799 times)
Offline Sigop
« on: February 15, 2018, 12:57:09 PM »
....rear fork pivot bolt.  Packed her full of grease.  Removed left side nut.  Right side just spinning.  Is it hammer and block of wood time from the left side? (Have not been removed since installation in Japan in 1973.) Swing arm rises and falls freely and is not binding.
Thanks. (You tube and Clymers no help this time.)
CB750 K3  Original Owner and Operator
Offline pjlogue
Re: Removing swing arm bolt....
« Reply #1 on: February 15, 2018, 01:13:21 PM »
Don't pound on the grease fitting!  Either use a section of pipe that will go over the grease fitting or gently wiggle out the grease fitting and then use wood or brass to drive the bolt out.  You might have to get a section of pipe that fits through the hole to get the bolt out.
-P.
Offline Sigop
« Reply #2 on: February 15, 2018, 04:25:30 PM »
Alright pjlogue.  Just wanted to  be sure I hadn't missed some threaded something in there.
Thanks.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #3 on: February 16, 2018, 03:58:54 AM »
I would spray copious amounts of penetrating oil on both sides of the bolt, and spin it so you can loosen any rust or gunk that may have accumulated. If you have an air or electric impact, you could spin it by the nut, and press on the grease fitting with a piece of wood to see if that would help start it out.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Sigop
« Reply #4 on: February 16, 2018, 05:22:02 AM »
Copy Yamahawk. Thanks.
Offline Sigop
« Reply #5 on: February 17, 2018, 05:58:41 PM »
Bolt now out by using small socket and drive over the grease nipple and just driving it through. Thanks for the help.
Pics now shown of the swing arm center collar after only being wiped down.  I have not cleaned it yet, but does anyone think I have an issue here with possible corrosion? The grease holes are clear and work.
Have not tried to remove the bushings yet.  Including pics of the original parts at end of swing arm with felt washers.  Feels like opening a time capsule.
Thanks.
Offline BobR
« Reply #6 on: February 17, 2018, 08:30:04 PM »
 Looks like it took a hit from rust and lack of lube. Bob
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
