Author Topic: Dresda swingarm for drum brake cb750  (Read 8300 times)
Offline T1m32sh1n3
Re: Dresda swingarm for drum brake cb750
« Reply #25 on: February 22, 2018, 03:48:56 AM »
Whats everyomes thoughts on that offset?
Offline Bill/BentON Racing
    • BentON Racing
« Reply #26 on: February 22, 2018, 05:17:04 AM »
K, sorry about the mix up.  Joe, I think George was next,  let me check with him and I'll get back to you,  thanks,  Bill
BentON Racing Website
BentON Racing Facebook
Offline gschuld
« Reply #27 on: February 22, 2018, 07:18:56 AM »
I’ll definitely take it.  But Sean asked about it first so I’d pass it along if he wanted it as per the unwritten fairness rules.  As it happens, I’ll be making up a set of adjusters for another swingarm anyway(Sean would know 🙄😁) so doing a 2nd set isn’t a big deal.
Sean, I’ll check in with you again once the new adjusters are done for it.  In case you change your mind.  You know I’ll treat you right😉.
FWIW, it’s highly unlikely this arm is either a Dresda or a Curtis arm.  As far as I know both Dresda and Dennis Curtis arms were tapered bearing pivot bolt arms, except for the very earliest Curtis arms, which this is not one of them.  Best guess is it was either a well made one off or a limited run from a custom shop.  The work appears to be of good quality regardless.
If anyone can ID who made this particular arm I’d appreciate it👍
George
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #28 on: February 22, 2018, 08:52:42 AM »
George
Oh ok now I see. Yes, yes, that is my work. Please return my work of art. Feel free to next day air that bad boy to me.... 🤣
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
« Reply #29 on: February 22, 2018, 09:03:14 AM »
I think the one Bill had is better built.
« Reply #30 on: February 22, 2018, 09:29:27 AM »
It does look a little sturdier than my dresda.   Nobody has any idea what's up with that offset dress one?
« Last Edit: February 22, 2018, 04:16:27 PM by seanbarney41 »
Offline JoeCooley
« Reply #31 on: February 22, 2018, 09:57:01 AM »
It does look a little sturdier than my dress.   Nobody has any idea what's up with that offset dress one?
The DOHC bikes have an offset to the swing arm. My guess is it was made for that application.
Offline OLD BILL
« Reply #32 on: March 01, 2018, 10:50:59 AM »
 I am also looking for an arm but for a 76F. Not partial to Dresda , Curtis or etc, as long as it fits and safe just normal street riding (love the look) Anyone have one?
    Thanks in advance
 Bill
Dream as if you will live forever,Live as if you will die tomorrow.
 JD
Offline Ricky_Racer
« Reply #33 on: April 01, 2018, 09:21:35 AM »
I have a couple NOS Dresdas: 750 and 550. I believe the one with the offset pivot may be for a CB550. At least mine is...
RR
Offline T1m32sh1n3
« Reply #34 on: April 02, 2018, 10:01:08 AM »
Cb750 nos dreda for sale?
Offline Ricky_Racer
« Reply #35 on: April 02, 2018, 10:11:02 AM »
Not yet, Bro.
RR
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #36 on: May 20, 2022, 03:11:18 PM »
Can you still get these swingarms new from anyone?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline gschuld
« Reply #37 on: May 20, 2022, 04:03:02 PM »
New custom made swingarm? Or NOS vintage swingarms?
George
Offline Ellz10
  • ZZ
« Reply #38 on: May 20, 2022, 06:07:55 PM »
George
The Dresda like the one from Carpys.
Offline gschuld
« Reply #39 on: May 21, 2022, 08:37:58 AM »
Ok.  FWIW, the Carpy arms are “Dresda style”, and have OEM style pivot bushings.
The genuine Dresda arms have tapered bearings for the pivot.  The Carpy arms I’ve seen are also wider at the rear axle ID than the true Dresda arms that I’ve seen.
So I assume you are looking for an aftermarket boxed swingarm, not particularly a vintage piece.
George
Offline Ellz10
  • ZZ
« Reply #40 on: May 21, 2022, 02:06:03 PM »
George
Yes, not interested in a vintage piece. Was curious if they were still available. I saw one from MGS Performance, but was unsure of the similarities between the two and if anyone had ever used or seen one in person.
« Last Edit: May 22, 2022, 09:21:28 AM by Ellz10 »
Offline gschuld
« Reply #41 on: May 21, 2022, 02:56:08 PM »
https://mgsperformance.com/product/custom-swing-arm-1975-1978-honda-cb750-mgs-performance/
The main obvious difference is in the shock mount/axle adjust section of the arm.  MGS arm has single plate style combination bracket.  The OEM swingarms used a casting in a similar manor.  OST aftermarket arms retain the 2”x1” rec steel tubing to the end with elongated slots for the axle, with adjusters inserted in from the back end.
Both work.  Of note is the MGS arm says it’s 1” longer than 75-78 arm specs(which is longer than earlier OEM swingarms).  So keep that in mind.
George
