Author Topic: Who knows CB750 K0 cylinder head vagiaries?  (Read 4759 times)
Re: Who knows CB750 K0 cylinder head vagiaries?
« Reply #25 on: March 30, 2018, 05:31:14 PM »
Well I sold the later K0 head a couple of weeks ago, and I thought that was the end of it, but then I came across this pic of a head from an early sandcast K0 which is different from the other two! I do remember reading somewhere here that there were at least 3, maybe 4 different K0 heads, so I'll add one more to this thread, just in case someone else is interested. Can you spot the difference? ;D
Weird K0 head by terry prendergast, on Flickr
Offline KayOne
« Reply #26 on: March 30, 2018, 05:58:11 PM »
Okay, I"ll guess, no press in oil jets, From the picture the oil jet holes appear to be drilled in the casting.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
« Reply #27 on: March 30, 2018, 07:56:57 PM »
There is a mould or spruce dot, outboard of each valve guide.
 And there is a boss intersecting the rib in the missing bolt area.
Offline BPellerine
« Reply #28 on: March 31, 2018, 06:55:01 AM »
the sandcast guys say that is a transition head,with the front boss provided for the front hole but never drilled,my 71 head has those dots.bill
1978 CB 750K ard and webers
another anfob
Offline Sgt.Pinback
« Reply #29 on: March 31, 2018, 01:10:54 PM »
Terry, do you have the correct breather cover for that early head?
Doc, I love a motorcycle!
« Reply #30 on: March 31, 2018, 01:14:58 PM »
EX guides as my K1 head on my k2 build  no guide seals.
My K1 head has press in oil orifices like shower nozzles. Not drilled direct in head as your early one. It has grainier alu than my K6 head which I noticed when repairing threads with time-serts. I torqued the valve cover less than usual.
« Reply #31 on: March 31, 2018, 05:46:07 PM »
G'Day Sarge, breather cover, or cam cover? I've discovered recently, with Bill's help, that I don't know sh1t about K0 engines? Tell me what I should be looking for? ;D
Offline Sgt.Pinback
« Reply #32 on: April 01, 2018, 01:35:51 PM »
Hi Terry,
Depends if you take early cam holders.
See # 272 for different breather covers:
http://cb750sandcastonly.com/smf_forum/index.php/topic,1701.270.html
« Reply #33 on: April 01, 2018, 10:53:41 PM »
Well I found these two in my garage this afternoon, are they the real deal? ;D
K0 breather cover 1 by terry prendergast, on Flickr
K0 breather cover by terry prendergast, on Flickr
Offline JamesH
« Reply #34 on: April 02, 2018, 04:21:27 AM »
Terry - did you win the sandcast cases/frame on eBay then?
Offline Sgt.Pinback
« Reply #35 on: April 02, 2018, 04:27:08 AM »
Inside Yes but can’t see if they are slightly higher on the rear side (carb side) as shown in my pic in SOOH forum
« Reply #36 on: April 02, 2018, 04:54:51 AM »
Ha ha, no mate, I was a very early bidder, but it was way too rich for my budget and anyway, I didn't want to get caught up in the endless pursuit for "unobtainium" sandcast parts. I've got enough parts to build a complete low numbers diecast K0 engine, which I'll then sell to finance my K1 build. ;D
« Reply #37 on: April 02, 2018, 04:57:22 AM »
Sorry Sarge, I tried to open it, but didn't see any pics? I think the one on the left is slightly different from the one on the right? ;D
Offline sandcastcb750
« Reply #38 on: April 02, 2018, 09:24:18 AM »
Seems to me that the sandcast head was used through beginning 1972 or K2. The 750 was severely de-tuned after 1971 so maybe there some other alterations in the head?
« Reply #39 on: April 02, 2018, 01:49:58 PM »
Yeah, I think "severely detuned" is a bit of a stretch, I've ridden every model CB750 and owned many, and apart from hotrodded bikes, in reality they all pretty much felt the same.
The big difference probably had more to do with gearing. Changing the front sprocket from a 17 toother to 18 gave later models a drop in acceleration but a more relaxed cruising at lower RPM's in top gear. The K0 cable carbs had a lighter pull too, which gave the rider the impression that the engine was a lot more willing than later models.
Sure, the K0/K1 might have had a couple more BHP, but nothing that noticeable. ;D
« Reply #40 on: April 02, 2018, 03:10:22 PM »
The 300 pipes helped.
 KO  had 16 45 gearing I think.
