Author Topic: Moisture in guages 76 750F  (Read 1092 times)
Offline Sellsme
« on: February 25, 2018, 01:53:02 PM »
What to do about moisture in gauges, is there a vent somewhere?
Don't try to make sense out of what don't make sense....
Offline Flyin900
Re: Moisture in guages 76 750F
« Reply #1 on: February 25, 2018, 02:05:10 PM »
Gauges are sealed from the factory and the only real opening is through the two bulbs that illuminate the faces and have rubber seals that push into the metal cases at the back of the gauge. You must have a break somewhere in the sealed set up that has let moisture into the faces.
The rubber seals maybe breaking down on the glass faces, or possibly the gauge lights aren't sealing the rear of the cases properly. You need to investigate a little further by removing the gauges from the mounts and did this just happen, or did you buy the bike with this issue?
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Sellsme
« Reply #2 on: February 25, 2018, 02:51:29 PM »
No, I think it was this way. I just bought not running went through everything and it purrs. this will be my second restoration, the bike is like new with 11,000 miles. Thanks for your reply
Offline Dunk
« Reply #3 on: February 25, 2018, 03:20:02 PM »
It's probably the large gasket between the gauges or the small flat rubber rings. I've seen them in "good" serviceable condition and I've seen them totally dry rotted and cracked. unfortuantely you have to remove teh crimp ring and recrimp to inspect. I am not aware of a source for any of these seals (anyone know of one?), but I had enough parts gauges when I restored mine that I had serviceable gaskets on hand that were still pliable and not dry or cracked.
Would be great if someone reproduced these seals for the gauges!
Offline Sellsme
« Reply #4 on: February 26, 2018, 05:51:11 AM »
I will remove the gauges and inspect, Thanks for your reply.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ak1qsbg14kb89cs2teqi2oas23&/topic,60973.0.html
« Reply #5 on: February 26, 2018, 10:00:58 AM »
have just done it on my boat gauges..they vent fine...
i hate all this v-w.... vords
