Author Topic: Oil temp sensor  (Read 5510 times)
Offline Deltarider
Re: Oil temp sensor
« Reply #25 on: March 01, 2018, 11:35:17 PM »
You can also do without. Honda thought so.
CB500K2-ED Excel black
Offline Paintedseat
Re: Oil temp sensor
« Reply #26 on: March 02, 2018, 06:09:12 PM »
Good. Glad it worked out
Re: Oil temp sensor
« Reply #27 on: March 02, 2018, 06:37:53 PM »
Put mine in the oil pan drain plug...that's where the oil drops after heating up before returning to the tank. Daytona makes all sorts of bolts that allow it
Offline Johnny340
Re: Oil temp sensor
« Reply #28 on: March 07, 2018, 11:06:14 AM »
::)  Honda also thought to do without making the engine 836cc with a big cam and a custom oil tank.  And, had they included a $767 gauge that has a temp reading then they surly would have hooked it up with a $3 connector.  :-X
Thank you for that useful post!  I will try this if my current solution doesn't work out.
Cheers. :)
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
Re: Oil temp sensor
« Reply #29 on: March 13, 2018, 04:20:01 PM »
Just to confirm that the setup I have here (borrowed from paintedseat  ;) ) works perfectly for both; the Honda oil pressure light, as well as the oil Motogadget temperature sender. :)
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Paintedseat
Re: Oil temp sensor
« Reply #30 on: March 13, 2018, 04:57:48 PM »
The the temp show up on the Motogadget gauge and which one are you using? I want to get this on https://revivalcycles.com/collections/for-your-ride-motogadget-gauges/products/motogadget-motoscope-mini
Offline Johnny340
Re: Oil temp sensor
« Reply #31 on: March 13, 2018, 05:11:47 PM »
I have the Motoscope Classic and it worked on T2 after I set up the minimum and maximum temperature. I'm not familiar with that one but I would think it would work as long as it has the input for it.
Sent from my SM-G930W8 using Tapatalk
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Paintedseat
Re: Oil temp sensor
« Reply #32 on: March 13, 2018, 07:43:26 PM »
Oh I know. I was just wondering which he was using.
