Author Topic: CB750 Hardwelded rockers: Dynoman vs CycleX vs Megacycle, same quality?  (Read 3990 times)
Hi,
I have seen that CycleX hardwelded rocker arms have a much better price. Are they done locally by CycleX?
- Anyone here that have tried them, preferable hard use in a racebike and later inspected the wear and found them OK?
Is the finish and durability of these as the Dynoman and Megacycle alternatives?  Other alternatives?
I have a hardwelded cam that probably need hardwelded rockers as I have understood when reading posts here about hardwelded cam vs stock rocker arms and opposite.
« Last Edit: February 28, 2018, 03:33:14 AM by PeWe »
Offline MessnerMoto
Re: CB750 Hardwelded rockers: Dynoman vs CycleX vs Megacycle, same quality?
« Reply #1 on: February 28, 2018, 05:39:31 AM »
Find a local shop that does hardwelding of rockers. Or somewhere near you
Usually shop that does it do it in this way(for sohc example)).
1. They remove chrome on 7 rockers, they leave one intact
2. Hard weld surface on 7 rockers with removed chrome
3. They put rockers in replicator machine(one by one probably) with master sample being the one rocker that is left intact.
 Replicator machine copies/grinds surface according to original one
4. When 7 are finished they repeat for one left
Offline gschuld
« Reply #2 on: February 28, 2018, 06:37:40 AM »
For that matter, you can bring in a full set of 8 plus one extra to use as the profile pattern.  This allows all 8 to be done at once, saving both them and you the extra time/money.
George
Offline slikwilli420
  • Master of Disaster
« Reply #3 on: February 28, 2018, 06:55:47 AM »
I found a place out in Cali that does it. They also make custom rocker towers/shafts and billet roller rockers. A billet roller rocker would be quite the setup for sure. For the $800 some charge to hardweld Ill bet you could get most or all of a set of billet roller rockers custom made.
« Reply #4 on: February 28, 2018, 11:04:21 AM »
Thanks guys for the responses. I do no have any cam welders around here in Sweden I'm aware of that can do rocker arms. I found on internet but that will probably cost more than order megacycle version and I'm not sure they do rocker arms.
The best is if they have done CB750 rockers before.
CycleX has a good offer for just under 500 USD.
Offline cbr954
« Reply #5 on: February 28, 2018, 12:13:28 PM »
I have used 3 sets from cyclex, never had issue.   Two sets are in drag motors and one set is in a street motor but none get many miles on them.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline MessnerMoto
I am paying 15eu locally per rocker... Pretty sure you can find someone locally/nearby country... It is a standard job...
A quick search found one mechanic that did that 2005 for almost 40 euro each. That man was old back then, maybe not in business today.
It would be better if finding local alternatives like CycleX, order 8 rockers, no cores to be sent in. Shipping from USA and customs here will add some.
Offline MessnerMoto
https://hbs-customs.de/allgemeine-motorarbeiten/
-13eu... but maybe it is old... contact them...
search for "Kipphebel schleifen" "Kipphebel Reparatur"
for sure it will be a lot cheaper then importing from US....
« Last Edit: March 01, 2018, 04:35:02 AM by MessnerMoto »
Thanks! Easier to find when I know more what to look for.
I got just an email answer from a guy in Germany that has raced his CR750 for many years with stock rockers. Min 0.1 mm lash and a good oil was his recipe to avoid problems.
I hoped his shop had improved rocker arms on the menu toghether with the +90rwhp upgrades he has.
« Reply #10 on: March 15, 2018, 01:14:14 PM »
My hardwelded cam got company today. The fresh rocker arms look good. Pads will hopefully be parallel with the cam lobes  ;D
One old rocker arm with chrome still OK as a reference.
Lets see when I'll change cam to the 125-20 and the new rockers from CycleX (by Web cam)
The cam that sit now need 4-2-1 and new dyno run first. Then swap cam and another dyno.
