Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 173361 times)
0 Members and 7 Guests are viewing this topic.
Offline Gurp
  • I'm no.......
  • Once was a...
Re: What did you do to your non-motorcycle vehicle today?
« Reply #1525 on: December 18, 2021, 03:35:14 am »
Took the 6.5 TD for a longer drive today. Suspecting a pinched wire between the trans sensors and the ECM. shifted to 4th a few times but not consistently.
prob going to do a fluid filter change as well
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
« Reply #1526 on: December 18, 2021, 10:36:15 am »
Getting medieval Dave...glad you were able to fix it.
Online Don R
« Reply #1527 on: December 19, 2021, 08:12:10 am »
This one
What is rim is that?
That's a 3.5x18 aluminum DID
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #1528 on: December 19, 2021, 08:14:27 am »
You have better pics?
Online Don R
« Reply #1529 on: December 19, 2021, 05:39:05 pm »
 I can do better, have this one now, I'm hoping it takes standard spokes, these suffered in the barn. I wish I could buy that goodyear slick new today.
« Last Edit: December 19, 2021, 05:41:20 pm by Don R »
Online Alan F.
« Reply #1530 on: December 19, 2021, 06:45:06 pm »
Don if needed this spoke length calculator works well.
http://earlymotor.com/leon/misc/html/spoke.htm
« Reply #1531 on: December 20, 2021, 11:47:09 pm »
I'm guessing that stock spokes will be too long Don. I've got a Borrani 18" rear rim with the raised spoke flange like that one, and had to buy CB750K7 (17" rim) spokes to lace it to a CB750 rear hub. ;D
Online grcamna2
« Reply #1532 on: December 21, 2021, 01:08:54 am »
The way the rim looks,as the angle of the way the spokes are laced to the rim spoke holes,it's possible that that particular rim was originally designed for a larger O.D. rear brake hub than the one it's now attached to;although it's still able to be laced-up ok and work well.
Online Don R
« Reply #1533 on: December 24, 2021, 09:18:50 am »
 The look of the spoke nipple holes gives me a little concern. The spoke hole appears large and the angle unperfect so you may be correct. The best part is that it is spoked now so I can take a couple of them off for ID. If 17" spokes work, it would be cool because the 750 A spokes come with nipple washers.
  I also got a 16" hog rim with all of the spokes on the same side of the hub. Too bad it sat in the barn for so long. The tire on it is about 5 1/4" wide.
Online Don R
« Reply #1534 on: December 24, 2021, 10:14:44 am »
 After the first of the year I'm pulling the 3rd member out of the firebird, swapping the gears to 3:89 with the 31 spline positrac and all new bearings. That ratio should play well with the turbo 400 and OD.  While it's apart I'm putting the full court press on getting the exhaust tig welded and finished.
Online grcamna2
« Reply #1535 on: December 24, 2021, 10:22:49 am »
Don,have you owned your Firebird for a long time ?
What color paint do you have planned for it when it's finished ?
Offline Shopdog
« Reply #1536 on: December 24, 2021, 01:57:16 pm »
Since I haven't even started on my cb550 (first bike) I figured I would post here. I'm typically a car guy and have 5 early fox mustangs. I've been cutting and welding up some patch panels on this '79 pace car. This is the newest acquisition. I have a completed/restored pace car, 79 cobra, 82gt, and an 82 capri as well. I moved this car to the front of the line because it's not too far from being a running/driving project.
« Reply #1537 on: December 24, 2021, 03:08:21 pm »
Cars, bikes, boats, anything with a motor, right?!!!   We recently bought this Mach 1 from my brother, he hadnt driven it in 5 years, finally convinced him to sell!
Offline Shopdog
« Reply #1538 on: December 24, 2021, 03:25:58 pm »
Beautiful car! I love my Fords but I'd be just as happy working on chevy or dodge.
Online grcamna2
« Reply #1539 on: December 24, 2021, 04:35:29 pm »
Stev-o,is that a 70' or 71' Mach 1? 351 Cleveland or Windsor ?
« Last Edit: December 25, 2021, 08:53:37 pm by grcamna2 »
Online Don R
« Reply #1540 on: December 25, 2021, 06:11:54 pm »
 I got it in late 1970, since became friends with the PO. As expected, he forgot to mention when his wife hit a fire hydrant in it. Thought it had factory air, when you tie into a project like all of the warts come out. My wife likes a green/gray color I'm leaning towards charcoal gray with dark silver Z28 style stripes, over T/A body panels.
Online grcamna2
« Reply #1541 on: December 25, 2021, 06:26:48 pm »
That's going to be a beautiful 'From the ground Up' full custom restoration.
I imagine you've spent many hours on this restoration;it's Well worth it  ;)
« Reply #1542 on: December 25, 2021, 07:06:45 pm »
Hey shopdog: I have a brand-new, in-the-box Holley 1bbl carb for the 200CID/3.3L straight 6 in those Fox-bodied cars.
Need one?
« Reply #1543 on: December 25, 2021, 07:23:06 pm »
In Fall 1971, both my brothers custom-ordered their 1972 Mach I Mustangs the same week. It took 10 weeks to get them. One brother had his completely restored in 1996 in his Van Nuys, CA neighborhood (it had the dual Ram-Air hood with dual exhausts and could run 170+ MPH, which he did twice in the 1980s), and it lasted 2 days before it was stolen and disappeared. The other brother still has his: 11 years ago it quit running (squarebore quad problems, couldn't find another one) so he started into resto: 2 years ago he finally got it done and found both a NOS power steering pump and a NOS squarebore quad for it. That one has the Cleveland 351W and he added the Ram-Air package (that is a lot of parts!) and dual exhaust. He lives in Missouri now, drives it to our favorite boyhood haunts where we used to live there as boys. At that same time (1971) I ordered my factory-custom-built 1972 El Camino with 402 CID/365 HP & Cowl Induction Hood, Muncie 4-speed, positrac, air suspension with custom light alloy wheels: biggest POS in my whole life! In 13 months I drove it 37k miles, had it in Chevy's shop with engine out 2 times for dumping oil all over my driveway constantly, it ate 4 power-steering belts and 2 sets of tires, and got 4 MPG (honest! 4 MPG!) in city driving in wintertime. I drove it to Florida (from IL where I lived then) in 12/72 and got a high of 12 MPG in florida, 9-10 MPG the whole rest of the trip, with a 17-gallon tank. I parked it in 1/1973 and sold it to the first guy to come to the door with cash-in-hand, got 30% of what I'd paid Chevy for it. Never again...
Offline Shopdog
« Reply #1544 on: December 25, 2021, 07:35:27 pm »
I have a 351 Cleveland block at the house. I've had several of them over the years and planned on building them, but always changed my mind. I'm going to actually do it some day. They're absolute screamers when built right. Nothing like the sound of a hot Cleveland revving to 8 grand!
Offline Magpie
« Reply #1545 on: December 26, 2021, 09:35:08 am »
Dec. 24'th put a deposit on another Honda.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=bbfshfb2ljcaarug4n282grs32&/topic,60973.0.html
« Reply #1546 on: December 26, 2021, 01:24:12 pm »
have made some rust vork on the pony.. its a 820..made in france..have a simca engine
« Last Edit: December 27, 2021, 06:12:13 am by strynboen »
i hate all this v-w.... vords
Offline 1080
« Reply #1547 on: December 26, 2021, 01:36:16 pm »
Is that a Massey Harris 22, If it is a 22 I drove one when I was seven years old back in 1964. My Dad also had a Massey Harris 44.
« Reply #1548 on: December 26, 2021, 04:00:50 pm »
I'm sure that's a great truck Cliff, but it's possibly the ugliest vehicle I've seen in recent years, obviously designed by a committee...... ;D
Offline simon#42
  • liverpool
« Reply #1549 on: December 27, 2021, 08:07:00 am »
i thought that , then scrolled down and terry had said it .
