Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 172896 times)
0 Members and 7 Guests are viewing this topic.
Re: What did you do to your non-motorcycle vehicle today?
« Reply #1675 on: March 07, 2022, 10:26:04 am »
 I watch the precision transmissions guy on youtube. He takes them apart on a morgue table and spots what is wrong and explains how he improves them, such as which check balls to leave out or what servo from a corvette will work.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #1676 on: March 07, 2022, 12:12:54 pm »
I am a fan of that channel and used his videos to work out what to buy for mine. I didn't go crazy with parts and it still added up to $700. I'll definitely be making a couple of the mod's that he talks about and got a rebuild kit with the Raybestos Zpack 3-4 clutches and wide 1-2 band. I supplemented my rebuild kit with a few Sonnax parts too.
It's amazing how fast he gets his transmissions apart. In 90 minutes of work Saturday I did about 50% of what he gets done in under 30 minutes.
« Reply #1677 on: March 07, 2022, 08:24:57 pm »
 It seems for a long time no one heard of Sonnax but they were quietly making most of the parts everyone else sells. I ventured inside my freshly rebuilt powerglide just far enough to make it work, it had grit in the relief valve and it was hung open.
   A few of the missing parts (not used in racing) threw me a curveball at first until the book got here. It has an original modified valve body.
   There was also a roll pin that kept backing out and releasing whatever it held in place. I forget how I fixed that, but I hope it doesn't need to come out someday and won't. L0L!
Offline MJL
  • Don't listen to me, I'm no
« Reply #1678 on: March 08, 2022, 02:30:38 pm »
Saturday it was 70 and sunny, which was nice for northeast Indiana, so I pulled the winter beater in the driveway to fix the exhaust. It was quiet when I bought it a few years ago, but I soon found out the exhause was scabbed together with tek screws and tin cans. Eventually, the pipe in the middle right under the seats fell apart and I've been driving it for quite a while with the exhaust ending right under the engine. Finally I bought one of those braided stainless flex couplers and some exhaust pipe and rolled around under the car cutting and welding. It's not perfect but it's loads better than listening to open exhaust.
Offline grcamna2
« Reply #1679 on: March 08, 2022, 04:41:24 pm »
I live in a 2nd floor apt. at the corner of a busy intersection in Davis,CA.,first time living in Such a LOUD environment.  >:(  I can only Hope that more auto owners start thinking like you do  8)
The noise is unbearable at certain times of the day. :o
« Reply #1680 on: March 08, 2022, 07:53:24 pm »
 Bankerdanny, this should clear up any questions that arise during the transmission rebuild,
« Reply #1681 on: March 08, 2022, 07:59:45 pm »
 ^ That guy made training films, and this reflected how he often felt while filming them. This was filmed at the end of such a day at the request of the "engineer"
  He reportedly invented the ear bud that todays reporters use so he could play the tape and repeat it accurately.
« Reply #1682 on: March 08, 2022, 08:08:24 pm »
 Data sheet, this has taken on a life of it's own.
 http://www.rfcafe.com/miscellany/humor/ge-turbo-encabulator.pdf
Offline Bankerdanny
« Reply #1683 on: March 09, 2022, 07:56:08 am »
The Turbo Encabulator. I have this bit on a VHS tape I got back in the mid 1990's from one of my wife's bosses who was an engineer.
« Reply #1684 on: March 10, 2022, 09:43:25 am »
 Oddly, I have seen a dinglearm up close. A friend was trying to get his NHRA top alcohol dragster license. The car never shifted into high gear, the car owner wanted to blame him repeatedly. When they finally pulled the Lenco trans and took off the cover, there was the high gear dinglearm hanging loose inside the case.
« Reply #1685 on: March 13, 2022, 01:52:14 pm »
I fried the trailer harness in our Grand Cherokee. Smoke was coming from under the plastic in the cargo area.  It scared the #$%* out of me. Luckily it stoped when I unplugged the trailer.
Offline Bankerdanny
« Reply #1686 on: March 21, 2022, 09:23:39 am »
Got the transmission on the Envoy 99% disassembled. This poor transmission has been beat on. The 3rd gear clutches were totally smoked, several components show evidence of severe overheating. As a result I needed to order another $150 in parts which should be delivered later this week and the reassembly should start next weekend.
« Reply #1687 on: March 21, 2022, 09:35:48 am »
My '70 Corvette was making a thump sound when I stepped on the brake pedal, it was coming from the front wheel area.  Pulled the front wheel, thought maybe the caliper had come loose. Turns out the bolt on the upper control arm had come loose and the shims apparently fell out.  Believe my buddy had a similar issue with his '65 Corvette recently, seems like a bad design.
https://www.ebay.com/itm/403466226718
« Reply #1688 on: March 22, 2022, 03:21:28 pm »
 Our Honda Accord has developed a thumping rattly noise under the hood, it does it moving and parked with the motor running. I already replaced the idler and belt. I'm considering letting the dealer put a guy to work for a couple hours and have the valves adjusted while it's there. 110,000 miles.
Offline BenelliSEI
  • 1969 cb750
« Reply #1689 on: March 23, 2022, 07:22:13 am »
I had the same thing happen to my old ‘03 Grand Cherokee. These units plug in as an “inbetween coupler” in the back end lamp harness. Apparently there was a recall on the Chrysler unit, that missed us! Bought an aftermarket unit at a local auto parts store, that totally solved the problem.
Offline Bankerdanny
« Reply #1690 on: March 25, 2022, 02:40:12 pm »
Drove the 50 miles down to my sister's and gathered up the disassembled transmission and all the parts and hauled them back to the city so I can work on them Saturday a d Sunday without spending $50 on gas driving there and back both days.
« Reply #1691 on: March 25, 2022, 10:32:50 pm »
my wife reverses her car out and selects drive before its stopped always,ive told her its bad,went bang this morning sheared the splined end off at the outer joint,guess who had to drive her to work,go fetch a new shaft and put it on,whats worse is ive gotta pick her up aswell at 6pm so i cant have a bloody beer till then!!
« Last Edit: March 25, 2022, 10:34:47 pm by dave500 »
Offline grcamna2
« Reply #1692 on: March 25, 2022, 10:58:30 pm »
That's a lot to ask of those CV joints,not to mention you Dave  :D
Offline Kelly E
  • Geriatric Hooligan
« Reply #1693 on: March 25, 2022, 11:07:39 pm »
I keep telling my wife that she needs to stop driving the car in traffic with the cruise control buttons on the steering wheel. Instead of using the pedal she's constantly speeding up and slowing down using the damn buttons. It's at least $1400 to fix it when it breaks. She's going to be mad when I laugh at her and tell her it's not my problem, I warned her.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online Terry in Australia
« Reply #1694 on: March 26, 2022, 01:34:47 am »
That sucks balls Dave, we've had the old green Hyundai for 20 years this year, and the only thing that's gone wrong with it was that it spat a brake pad. Even the tyres I put on it then are still roadworthy. I wish it would die so I could send it to the tip, but while it keeps going, she won't let me get rid of it. ;D
« Reply #1695 on: March 26, 2022, 01:54:01 am »
yeah i quite like the cheap n cheer full little #$%* heaps,whole new drive cv axle was only 160 bucks,only took an hour and a bit to swap it out.
Offline grcamna2
« Reply #1696 on: March 26, 2022, 10:07:52 am »
Dave,they give you a guarantee with that  CV axle ?  :D
« Reply #1697 on: March 28, 2022, 01:11:57 am »
i guess itll have the statutary one by law,but once they see my wifes driving itll be void!
« Reply #1698 on: March 28, 2022, 04:21:57 am »
I installed the nid mount cutting deck on my Kubota, always a treat.  ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #1699 on: March 30, 2022, 10:15:54 am »
The guys I Endurance Race with decided three seasons (32 X 8 hour races) was enough seat time in the Toyota MR2 Turbo. Today we concluded a deal on an ex Lexus Grand Am factory racer. Really well built sedan that looks the part. First race weekend in 17 days!
« Last Edit: March 30, 2022, 12:12:49 pm by BenelliSEI »
