Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 208468 times)
grcamna2 and 1 Guest are viewing this topic.
Offline CycleRanger
  • No comment about being an
Re: What did you do to your non-motorcycle vehicle today?
« Reply #175 on: July 01, 2018, 05:29:46 AM »
In the past week to my '02 Tundra,Replaced the brake master cylinder. Flushed out all the green! brake fluid.Installed new front pads.Replaced the oil pressure gauge. Really nice to see oil pressure again!
Replaced the burned-out "D" light in the dash while I was there.Got the 15+ year old faded window tint replaced.Broke the handle for the tail gate...
The bikes got nothing! :(
Online Don R
« Reply #176 on: July 02, 2018, 08:23:27 PM »
 Put on fresh upgraded roll bar padding, bought an msd 4 relay module for improving the starting circuit, new hose on the tire gauge, made a list of all the things I need to do including taking the body off to expose the wiring. I had to hot wire the starter circuit at the track to save the new flexplate, it wasn't operating the starter solenoid efficiently and grinding the teeth.
« Reply #177 on: July 07, 2018, 03:55:30 AM »
well I finished off my suspension maintainence,or so I thought,i did the sway bar mounts and links today,i used rubber on the links and soft urethane on the body mounts,i replaced those link rods about 4 years ago but they've rubbed on the wishbone through hole halfway through and elongated the holes in the wishbones!no big deal ill get new links and weld on a washer or drilled plate to re set the wishbone holes later,another day,its much softer now after all the rubbers are new and the way it should be.
« Reply #178 on: July 07, 2018, 10:31:24 AM »
Had a slow leak on the L rear of the wifey's Nissan, upon inspection we discovered a slice on the tread.
So installed new BF Goodrich's on the rear, 275mm wide....
Then took it for a "test drive" on one of my favorite roads!
Offline CycleRanger
« Reply #179 on: July 10, 2018, 01:18:02 PM »
Replaced the broken tailgate handle on the Tundra.
Got the lid for the center console reupholstered over on the east side.
Programmed two new alarm keychain fobs. What a PITA it was to access the RS3000 ECU module way up under the dash.
Again, the bikes get nothing. :(
« Last Edit: July 10, 2018, 01:19:47 PM by CycleRanger »
« Reply #180 on: July 14, 2018, 12:24:11 AM »
as promised I replaced the sway bar links,i used to have this car really low im thinking that cranked the links into an unnatural angle or something causing this wear?then again it is a daily driven all purpose 1973 car!
« Last Edit: July 14, 2018, 12:27:12 AM by dave500 »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=a00qn86o5cet9e8aq69la98kf1&/topic,60973.0.html
« Reply #181 on: July 14, 2018, 03:08:07 PM »
made the boat ready to be craned to sea..have thanged all pexiglass windovs..and made a nev fuel tank and copper fuel line..and revired most elektric
« Last Edit: July 14, 2018, 03:10:56 PM by strynboen »
i hate all this v-w.... vords
« Reply #182 on: July 14, 2018, 09:42:48 PM »
how long is it stryboen?i mean captain strynboen!
Offline strynboen
« Reply #183 on: July 15, 2018, 02:25:58 AM »
ohøy....20 fod.
.a small boat...its a mix betveen a Work/fising boat..and a weekend sailer...build to hold.. abaut 10 mm thik..and near 2 tons ,,a bit heavy..and slov..but safe and steady. have a Volvo penta md 11- 2 cyll engine 24 hp- sea vater cooled..
.51 years old..so a Classic ship..just like aur bikes and cars...
« Last Edit: July 15, 2018, 02:33:03 AM by strynboen »
Offline dhall57
« Reply #184 on: July 15, 2018, 03:22:26 AM »
Put a new alternator on my 1990 Silverado
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #185 on: July 16, 2018, 06:59:18 AM »
Nice!
« Reply #186 on: July 16, 2018, 11:45:34 AM »
its steamboat willie?
Offline strynboen
« Reply #187 on: July 16, 2018, 12:50:11 PM »
Willie..is better then titanic.
.vas willie the one vho dropped a torpedo dovn in the head of a japanese u boat?? and blov it self up...??
Offline 74cb750
« Reply #188 on: July 17, 2018, 04:05:57 AM »
ohøy....20 fod.
nice boat  :)
Laugh at least once a day.
Life  $ucks, then you die.
Offline 74cb750
« Reply #189 on: July 17, 2018, 04:08:18 AM »
is a lawn mower a valid vehicle to comment about?
Think I might have to replace the cutting blade shaft on mine. We have many rocks in Vermont which seem to grow from the ground up. It might be cheaper to just buy another Honda motor.... :'(
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #190 on: July 17, 2018, 07:23:40 AM »
Shouldn't the blade shaft be the end of the crank?
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline Bankerdanny
  • Endeavor to persevere
« Reply #191 on: July 17, 2018, 01:02:16 PM »
If it has a motor and you can ride in or on it then it is a vehicle in my book.
« Reply #192 on: July 28, 2018, 01:50:10 AM »
not mine but a mates skip bin truck,warren who rides a ducati with us wanted to move the bin locating strips on the deck,a simple cut the welds move and reweld?yeah right took almost two hours with us both on angle grinders simultaneously using his 7100 watt briggs powered genny,then we found the genny wouldn't quite run his new inverter welder at the amps we needed so relocated to my place to finish it off,its winter here but still hot and bright in the sun!he has a nice convertible mustang aswell in left hand drive.
« Reply #193 on: July 28, 2018, 10:56:44 AM »
Nice Mustang, Dave.  '68?  My mate just bought a '66 'Stang for wife...
[I found it in Dallas for him]
« Reply #194 on: July 28, 2018, 11:03:16 AM »
I started pulling the '70 Corvette interior apart to install a new dash pad, gauge bezel, console and Alpine audio system.  Came apart pretty quick, many screws were missing! The PO must have been a butcher looking at the way the [crappy]stereo was installed.
Challenge #1: need to figure out how to mount modern Infinity 4x6" speakers in the original place in the dash...
Offline strynboen
« Reply #195 on: July 28, 2018, 01:27:36 PM »
aut on the open sea....
« Reply #196 on: July 29, 2018, 01:34:11 AM »
Offline vfourfreak
  • Do you think that's wise
« Reply #197 on: July 29, 2018, 03:43:14 AM »
its captain pugwash!
. . and Seaman Staines ??
Kev
Offline strynboen
« Reply #198 on: July 29, 2018, 10:11:01 AM »
had started on the hilux rust and leaky fueltank..it vas luckly only the fuel lines vho vas rusted..
Offline spotty
« Reply #199 on: July 29, 2018, 08:10:48 PM »
Kev
favourite line...." ee Jack you're late "   repeated just about every episode
i blame Terry
