Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 171367 times)
0 Members and 20 Guests are viewing this topic.
Offline BenelliSEI
  • 1969 cb750
Re: What did you do to your non-motorcycle vehicle today?
« Reply #2225 on: September 14, 2022, 07:10:26 pm »
Not mine but I'm doing a 26 hour each way trip to Reno Nv with a friend to pick up an old car. I don't even know what it is. We're roughing it, taking his Tahoe and open trailer instead of his motor home. The trailer is sitting at the farm, I hope the tires are recent.
Haven’t done one of those in a while! Sounds like fun. Found out what car yet?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2226 on: September 17, 2022, 03:46:32 pm »
Got in some parts for my 61GMC and ordered some stuff for the 63 Bel-Air.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
« Reply #2227 on: September 19, 2022, 02:20:34 pm »
Got some "new" wheels and rear tires for the buggy...
The front tires are what came on the set of wheels that I bought locally, they are really old and too tall. They rub when I go thru the woopties!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2228 on: September 23, 2022, 08:40:31 am »
Got the 4L60E rebuild project back on track and got all the insides back inside. Now I just need to get the shifter bracket, valve body, and servo's back in and it will be time to install and see if I did it right.
Offline BenelliSEI
  • 1969 cb750
« Reply #2229 on: September 23, 2022, 09:45:07 am »
The rental Echo is ready for next weekend. Two X 8 hour Endurance Races at Calabogie. Just finished up installing a fresh motor in the Lexus, should be ready in a day or two.
« Reply #2230 on: September 23, 2022, 11:02:28 am »
People are fixing up their older cars rather than buying replacements these days so getting service and replacement motors is a challenge for many vehicles these days...
Offline Kelly E
  • Geriatric Hooligan
« Reply #2231 on: September 23, 2022, 04:07:57 pm »
I guess that won't be an issue for me since I never stopped driving older vehicles, that's all I own. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #2232 on: September 23, 2022, 05:12:46 pm »
 It was a 63 chevy II. The seller lied and the floors were rusted out. We left it there in his driveway and returned with the trailer empty. 5 days and 5 hours round trip.
Offline BenelliSEI
  • 1969 cb750
« Reply #2233 on: September 23, 2022, 05:43:11 pm »
Ouch!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2234 on: September 24, 2022, 04:56:43 am »
Still haven't unlocked that 283 in the 63. Started to strip it. Prob going to drop a good 350 in our of a 85 Chevy van. Lower miles good runner till the van was wrecked.
Offline BenelliSEI
  • 1969 cb750
« Reply #2235 on: September 24, 2022, 01:55:07 pm »
Replaced the cracked coolant overflow tank on the Volvo C30. Small amount of blood......
Offline grcamna2
« Reply #2236 on: September 24, 2022, 03:38:28 pm »
The swap to the 350 sounds good,plus you can remove ALL the pollution control stuff from that donor engine !  :D
« Reply #2237 on: September 25, 2022, 03:00:06 pm »
 We drag raced at Byron Il. n Super Comp. We went three rounds yesterday but lost first round today on a -003 red light.
 The track was slick and got better as the day went on. New track owners and a nationwide shortage of traction compound has changed the racing. We used to run hard, close to 8.90 and consistent, now it takes a quick setup and a wheel man at the finish line using brakes and throttle to stay inches ahead of your opponent.
 If it stays like this, we may find another venue. Maybe top speed racing. It needs tires next year anyway.
« Last Edit: September 25, 2022, 03:05:24 pm by Don R »
« Reply #2238 on: September 25, 2022, 06:23:21 pm »
Back when I raced RC cars we would use cheap sugar laced soda on the asphalt as traction compound enhancer, using prayers to apply on the racing line around the track...
But we ran foam tires and traction compound used for those wasn't sugar water of course...
Offline Bankerdanny
« Reply #2239 on: September 26, 2022, 11:48:11 am »
Put 6 brand new Motorcraft spark plugs in the Lincoln. It has the 3.5 twin turbo EcoBoost V6 in it with 110,000 miles. I was experiencing multiple misfires when I got hard into the turbos and would occasionally trip the check engine light.
The job was pretty straight forward, even the rear cylinders only required removing one nut and a couple of hoses to get enough room to slide the plus caps off. All the plugs were showing a nice tan color, but you could clearly see on the old plugs where the super fine iridium tip of the plug was gone compared to the new plugs.
Hit the throttle hard merging on the highway last night and no hesitation.
« Reply #2240 on: September 26, 2022, 02:13:49 pm »
 A video of our dragster shows the launch and it's way too soft. I over-cured the wheelie problem, the starting line rpm needs to be higher and maybe a little more time at wide open throttle before we go on the 4250 rpm throttle stop. That used to last 2.2 seconds plus or minus, right now it's around 1.6 seconds.
 On the good side, with the fresh fuel the top end mph is back to 173 which says the horsepower is still there.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2241 on: September 27, 2022, 04:59:27 pm »
Made a new door stopper bar mount.
Mounted my new light.
Tomorrow going to add a switch to the light and double check my dwell and timing. Truck has has a bit of a low rpm miss and sluggish pulling out.
Sent from my LE2127 using Tapatalk
Offline BenelliSEI
  • 1969 cb750
« Reply #2242 on: September 29, 2022, 06:48:50 pm »
Loaded up the Echo “rent a racer” and the Lexus race cars. My team mate, that gets a new GM truck every six months, is picking up a new one this evening. Diesel fuel is over $2/litre here today, so this one is gas. Pictures tomorrow. “Break In” in this weekend pulling the Echo to Calabogie for another double header. Eight hour Endurance races both days. We have 4 drivers signed up for the Echo, but my friend from Calgary can’t make this event. Only three of us in the Lexus, so lots of laps this weekend! Can’t wait.
« Last Edit: September 30, 2022, 08:05:32 am by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #2243 on: September 30, 2022, 08:00:56 am »
Little car is loaded....
Offline BenelliSEI
  • 1969 cb750
« Reply #2244 on: September 30, 2022, 08:02:22 am »
Lexus has a fresh motor. Fingers crossed.....
« Reply #2245 on: September 30, 2022, 11:44:21 am »
Safe travels, racing and time at the track John. Have fun and enjoy the hobby, hope you do well and new motor runs flawlessly...
« Reply #2246 on: October 01, 2022, 12:43:38 am »
Well i had an exciting morning flushing and replacing my coolant,also replaced the top hose had one handy,summers coming up,it wernt real crappy but i could see through it,got a 50/50 mix this time of nulon long life coolant,just keep on top of things.
Offline BenelliSEI
  • 1969 cb750
« Reply #2247 on: October 05, 2022, 06:01:44 am »
Perfect weather and had a great time! The little Echo ran flawlessly and the guys managed to collect enough points to end the year 2nd in Class. One of our Lexus drivers (my friend from Calgary) couldn’t make it, so we only had three drivers. Marc had a Family Emergency late Saturday, and had to get back to Montreal, and fly to Halifax! Tim and I did double two hour stints on Sunday, and finished 2nd in Class, both days. We had a blast!
Tim did a double stint on Saturday (it was his turn), so he spent 8 hours in the car, over two days!!! Our lap times on the +6 kilometre road course calculate to +125 KPH laps. We covered over 2,000 kilometres over the weekend and Tim drove 1,000 kilometres!
« Last Edit: October 05, 2022, 06:05:50 am by BenelliSEI »
« Reply #2248 on: October 05, 2022, 07:04:32 am »
Sounds great John, congrats.
What track, Mosport? [CTMP]   My brother has raced there many times in an SCCA SRF...
Offline BenelliSEI
  • 1969 cb750
« Reply #2249 on: October 05, 2022, 07:30:10 am »
Steve….. Mosport is 20 minutes down the road from our farm. I’ve been racing there since 1970 (including every SCCA Regional), so our paths probably crossed! This weekend we were at Calabogie, in the Laurentian Mts. +6 kilometres of rolling track, Fall colours were in full bloom. Sunshine and blue skys all weekend! One of the guys was taking pictures. I’ll post a ew when he sends them.....
« Last Edit: October 05, 2022, 08:50:17 am by BenelliSEI »
