Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 170074 times)
0 Members and 11 Guests are viewing this topic.
Re: What did you do to your non-motorcycle vehicle today?
« Reply #2650 on: May 15, 2023, 07:14:52 am »
Replaced the original battery in my 2012 Corvette. Only got 11 years out of it! WTF?! No tender use while gone either
Hey Jerry...thats amazing!  Battery on the C6 is under the hood, right?  Any issues with the ECU booting back up if the old battery was dead dead?
Offline BenelliSEI
  • 1969 cb750
« Reply #2651 on: May 15, 2023, 07:45:41 am »
Congratulations on a successful outing with great results! You got your groove back!
Really cool first event for the team.
So, how much you owe the wife for racing on Mother's Day?
David
One of the guys that races on another Team is a florist. He set up a special we all bought into, deliveries on Saturday afternoon. We all scored some extra points!!
« Reply #2652 on: May 15, 2023, 02:56:50 pm »
Good way to look out for each other!
Offline rluser
« Reply #2653 on: May 15, 2023, 10:21:22 pm »
Brake job on the '18 Soul.  Turned out to be just front pads.  I briefly thought it needed rotors, too, but that was from misreading the spec.  Older ones put more mass in the rotor. Routine... not exciting.
« Reply #2654 on: May 16, 2023, 07:12:45 am »
Finished the brake upgrade on the "ol' Chevy".  Upgraded the four Delco calipers, pads, hard lines and [Goodyear!] rubber hoses, then was able to bleed it after the blocked hoses were replaced. Was only able to take it for a short test drive before the thunder and pouring rain set in.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2655 on: May 16, 2023, 08:41:33 am »
Wow, Steve-o that's a beautiful machine!
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
« Reply #2656 on: May 16, 2023, 09:48:59 am »
Thanks...I've missed driving it and am happy it is back on the road.
« Reply #2657 on: May 16, 2023, 10:33:37 am »
Let the good time roll ! or should I say that about your Kawasaki's instead ?
« Reply #2658 on: May 16, 2023, 12:53:56 pm »
Kawasaki, Chevy, Honda or even Ford...say it, I dont mind, as long as they are rolling it's a good time!!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2659 on: May 16, 2023, 04:18:36 pm »
That's me as long as it's rolling. I'd prefer not a Ford, hell I've had a good time in one of those even!
« Reply #2660 on: May 17, 2023, 06:54:34 am »
I'd prefer not a Ford...
Many different types of Ford! Plan to drive this one today...
« Reply #2661 on: May 17, 2023, 08:26:39 am »
Nice ass that car has !
Offline BenelliSEI
  • 1969 cb750
« Reply #2662 on: May 17, 2023, 11:40:51 am »
Brewed up a full tank of two stroke gas for the Yamaha G1 golf cart. Steering box was dry, so greased up the front wheel bearings and king pins too...... G’kids are coming for the weekend, the cart will get no rest! Amazing device, soaks up all the punishment and keeps on running.
Offline C317414
« Reply #2663 on: May 17, 2023, 01:42:48 pm »
I serviced our lawn tractor, and put it to work.   ;)
« Reply #2664 on: May 18, 2023, 06:43:25 am »
This is a first. The central blade on the cutting deck was loose. Turns out the bolt was worn wafer thin. I had to weld a rod to it to get it out.
« Last Edit: May 18, 2023, 07:08:46 am by 70CB750 »
Offline Kelly E
  • Geriatric Hooligan
« Reply #2665 on: May 18, 2023, 11:10:30 am »
I replaced all 3 belts on the mower along with a freshly sharpened set of blades.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline grcamna2
« Reply #2666 on: May 18, 2023, 11:26:58 am »
The top belt is quite long;do you expect it to stretch much ?
Offline Kelly E
« Reply #2667 on: May 18, 2023, 11:46:06 am »
Not really, I just replaced the original set of belts. I bought the mower with 44 hours on it in 2011.
1983 Honda CB 1100F
« Reply #2668 on: May 19, 2023, 04:58:43 am »
Blades on the Kubota deck are held down by a bolt and two big concave washers.  Concave to provide preload for better holding.  Over the time they go flat and the preload decreases.  Yesterday, I solved it in pure redneck style.  Using a hitch ball and BFH I renewed the concavity for all the washers.  It should be good for quite few more years.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2669 on: May 19, 2023, 05:10:03 am »
I always support the use of a BFH!
« Reply #2670 on: May 19, 2023, 08:25:12 am »
 I received a set of radiator baffles from classic car parts for the Firebird. They close off the area above the radiator to keep the air going where it needs to. My car didn't come with them since it's not a factory AC car. It will be now.
 I'm going out to give them a test fit to determine if I need clip on nuts or whatever.  Sometimes you think shipped parts are overpackaged but the end of one panel was poked through the inside box.
« Last Edit: May 19, 2023, 08:28:58 am by Don R »
« Reply #2671 on: May 20, 2023, 01:27:18 am »
when in trouble or in doubt,get a bigger hammer out!
« Reply #2672 on: May 20, 2023, 03:16:54 am »
It crossed my mind that I could use my new hydraulic press to do it, but bfh was quicker and good enough.
Offline grcamna2
« Reply #2673 on: May 20, 2023, 08:30:01 am »
Wonderful project Don.  8) 8) 8)
Offline BenelliSEI
  • 1969 cb750
« Reply #2674 on: May 24, 2023, 03:29:46 pm »
Went to see the wife of a guy that raced with us a lot, +25years ago. He’s not doing so well and she is “cleaning house”. I may end up with my final project…..
Very early 1956 Porsche Speedster. He did a lot of metal work 20 years ago. Tub is all rebuilt, fresh steel, in primer. Everything else needs done. “Some assembly required”!
