Author Topic: carb upgrade jet size for c750k 1977???  (Read 884 times)
Offline Xander^
« on: March 06, 2018, 05:04:07 AM »
im going to run a CARPY 4into1 exhaust and cognito moto's airbox .. which jet size/ rebuild kit should i get for my carbs to work hand in hand with that intake and exhaust ??
sorry im a noob
1977 CB750K cafe
Re: carb upgrade jet size for c750k 1977???
« Reply #1 on: March 06, 2018, 07:02:39 AM »
You will find some disagreement on this. I am running a bone stock 78K. I have 120 mains and I have no carbon problem and no flat spot through the whole RPM range. They leaned them out for the EPA.  With a modded airbox and exhaust you will need the 120's.
Offline Paintedseat
« Reply #2 on: March 06, 2018, 08:26:41 AM »
Get slow jets too. 40s. Stock is 115 so you could probably go to a 125. You can also adjust the needles. Make sure you get keihin parts and not knockoffs.
 http://m.siriusconinc.com/search-result.php?make=1&model=Cb750k&part=1&partno=&search=search&start=50
Offline Xander^
« Reply #3 on: March 06, 2018, 08:56:30 AM »
would you say its safe to go with this stock complete 115 kit and then buy the 125 jets separately?
i saw a nice complete set at vintagecb750 and have a good exp ordering there...$25.95 USD
http://www.vintagecb750.com/products/6/fuel-system/37/carb-rebuild-kits-carb-floats-carb-items?gclid=EAIaIQobChMIoZeoupHY2QIVjVcNCh0LGAUVEAAYASAAEgL8CfD_BwE
1977 CB750K cafe
Offline Xander^
« Reply #4 on: March 06, 2018, 09:18:03 AM »
also found this!!! sweet deal ... i think? this includes the 110 main jet, and 35 slow....
can i get this kit and just swap out the main jets for 125 and get 40s?
http://4into1.com/ultimate-carburetor-rebuild-kit-honda-cb750f-1977-1978-cb750k-1978/
1977 CB750K cafe
« Reply #5 on: March 06, 2018, 09:40:32 AM »
Nice kit and you get new floats and formed float bowl gaskets. You can swap out the jets of course. These are all discreet parts.
Offline Paintedseat
« Reply #6 on: March 06, 2018, 12:05:08 PM »
What kind of shape are the carbs in? Use the stock needles as long as they are not corroded. The aftermarket ones are more lean than stock. The kit looks good. I would just purchase Keihin jets.
