Author Topic: HELP! Need Identification of Part  (Read 791 times)
Offline Madn3ssRaven
« on: March 07, 2018, 09:56:02 PM »
Hi guys,
Im just about done with my rebuild and when i was wrapping up last night after putting the carb cables on and starting on putting it on the carb boots I found this part. I think it might be part of the carbs but I havent seen anywhere it would go. Any help would be great.
Re: HELP! Need Identification of Part
« Reply #1 on: March 07, 2018, 10:06:37 PM »
« Reply #2 on: March 07, 2018, 10:34:22 PM »
My brain isnt thinking right now.
I have a 1981 650C
« Reply #3 on: March 08, 2018, 05:19:19 AM »
 What year and model of bike ? Looks a little like those throttle cable repair ends you can use if the fitting breaks off the end of the cable but most do not have the hex end. Hmmmm.
« Last Edit: March 08, 2018, 05:35:15 AM by ekpent »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: March 08, 2018, 08:29:55 AM »
That is definitely a cable end, but it is also not anything that was stock to a SOHC4. I think Eric has it right, it was probably intended to be a temporary fix for a throttle cable that lost an end.
The cable fits in the slot and the hex end keeps it from twisting while you use a screw driver to tighten the clamping screw.
« Reply #5 on: March 08, 2018, 08:37:32 AM »
Some people carry them gets you out if a jam. It may have been fastened into an empty hole son it is always there.
 Ie, I used to always carry a spare master link back in the day,  clipped over my clutch cable where it exits the clutch housing on a 750.
