Author Topic: I think i did something really wrong when cleaning my bike  (Read 3044 times)
Offline aminemed
Re: I think i did something really wrong when cleaning my bike
« Reply #25 on: March 11, 2018, 03:26:14 PM »
Can i use the same gasket again or do i need to change it by a new one ?
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #26 on: March 11, 2018, 03:33:15 PM »
if it's still in good shape use it again.  i just changed mine today.  yamahawk tipped me off on using chassis grease on both sides of the gasket.  holds it in place nicely while placing the cover on.
cb750 k6 - ugly
Offline aminemed
« Reply #27 on: March 11, 2018, 03:54:12 PM »
Thx
Starter clutch is located behind the rotor righter ? I believe i need a special tool for that right?
« Reply #28 on: March 11, 2018, 05:49:02 PM »
 I use a little contact cement on the cover side and chap stick on the engine side. That way the gasket stays on the cover and slips off the case when you take it apart again. The cover is easier to clean up on the work bench if you need to remove it.
Offline evinrude7
  • not a kung-fu
« Reply #29 on: March 11, 2018, 05:49:50 PM »
i believe it is.  not sure on the special tool.  this is beyond my current pay grade.  quote "progas", "swoop" and "jgger"'s posts in a reply.  someone should pipe up soon.  what bike is it?
cb750 k6 - ugly
« Reply #30 on: March 11, 2018, 05:53:09 PM »
 It's rumored a big bolt or the oil filter bolt will remove it. I've never had luck with that and bought a puller bolt for a few bucks off ebay.  In my opinion the oil filter bolt is too delicate.
 There are springs and rollers in the starter clutch. I've had them jump out of place before. I stretched the springs a little, reassembled and so far so good.
« Last Edit: March 11, 2018, 05:55:14 PM by Don R »
Offline aminemed
« Reply #31 on: March 12, 2018, 02:12:09 AM »
Don't know if this is related to my issue, but since 6 months, i have trouble engaging 1st gear, need to push hard. It also has this bad tendecy to go back to neutral.
Offline aminemed
« Reply #32 on: March 12, 2018, 03:38:24 AM »
You might have leaked gas into the cylinder causing it to lock up, that would explain why the kickstart doesn't turn it over. Then you would have to check your starter clutch, behind the dyno cover to see if the bolts are sheared off. You did say you had a gas leak right??
How can i fix that ? if i have this cylinder locked up..
Offline Progas
« Reply #33 on: March 12, 2018, 03:54:42 AM »
If you did leak gas into your cylinder, you would have to take the spark plugs out and kick it over. Yes, you do need a special puller for the rotor, easy to get on ebay, or I've heard you can use your rear axle(same thread). If you hurt your gasket you will have to replace it of course, I use gasketcinch to hold the gasket in place. Inside your starter clutch are three rollers, three spring caps, and three springs, the rollers need to be checked for flat spots along with the surface of the starter gear which they roll on. If your starter motor needs help, Rick's motor sports electrics can re-build that one for you or sell you a new one. They are located in New Hampshire and are great to deal with!
Offline aminemed
« Reply #34 on: March 13, 2018, 07:17:56 AM »
ok i've found the guilty item: the reduction gear, see the picture. Completely broken ! i don't know how it became like that
« Last Edit: March 13, 2018, 07:24:07 AM by aminemed »
Offline ts354
« Reply #35 on: March 13, 2018, 07:42:13 AM »
Ouch  :o
« Reply #36 on: March 13, 2018, 07:49:45 AM »
 Do you have the large flat washer that goes with that also ? Hopefully just replacing that will make for an easy fix. You do not have a location listed, are you in the USA. Plenty of those gears around,not a rare item.
Offline aminemed
« Reply #37 on: March 13, 2018, 07:59:51 AM »
i'm in europe, but i've found someone selling the reduction gear. I have the large flat washer.
I'm wondering what can cause teeths to brake..
« Reply #38 on: March 13, 2018, 09:05:09 AM »
 Maybe a backfire while it was turning/starting,who knows for sure. Is the mating gear it goes to look good ?
Offline aminemed
« Reply #39 on: March 13, 2018, 09:12:17 AM »
yes look good, i'm wondering if i don't have some play at the shaft of the starting motor. I'll check later on when back from work.
« Reply #40 on: March 13, 2018, 09:42:41 AM »
 My concern would be, where are those missing teeth? Hopefully they stayed in the dyno cover. I'd do a little recovering and counting.
Offline aminemed
« Reply #41 on: March 13, 2018, 10:05:34 AM »
now i understand why i had kind of a powder going out through my 4th carb pod filter...
Offline aminemed
« Reply #42 on: March 13, 2018, 12:25:38 PM »
There is no play at all at the starting motor shaft really dont know how those teeth broke. Lack of oil ?
