Author Topic: Tank Rubber Mount Help  (Read 851 times)
Offline JonathanHValencia
« on: March 11, 2018, 09:39:47 PM »
Hey folks,
Trying to fit a cx Deluxe tank on my cb. The rubber mounts are in the right place, just don’t reach out far enough to make contact with the cx Mount in the tank because the tank is a bit wider. Any suggestions on compensating for the distance, safely?
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: Tank Rubber Mount Help
« Reply #1 on: March 12, 2018, 01:43:04 AM »
Are you referring to the front two rubber donuts the the tank located onto... or the rear rubber mount? If it is the front two, you might look for some longer rubbers from a different bike to make up the distance, or bonding on a piece or rubber from another set, cut to length. If the distance is too great, cutting off the u shape on the tank on each side and shimming it with some plate tacked on will work. Careful welding and tank cleaning is a priority here for safety. How much room are you needing to compensate for?
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #2 on: March 12, 2018, 08:18:57 AM »
It’s about 3/4 of an once from the U on each side
Offline Yamahawk
« Reply #3 on: March 12, 2018, 09:27:40 AM »
It is 1 1/2" total width wider than the CB750 tank then, so you will have to see if there is a way to extend the tube on the frame by 3/4" and reinstall the rubber donuts. I would get some thin plate, and a piece of tubing the same diameter and length as the ones on the frame, and tack them on the plates, and tack the plates on the existing tube mount for the donuts, and then install the rubber donuts on the new tube... am I making sense? Hopefully so. And, if you need to move the tank forward or back, up or down, on those mounts, it would be easy to do by adjusting the tube tacked onto those plates, by the size and location of the plates you will tack onto the existing tube.
Charlie
« Last Edit: March 12, 2018, 09:32:31 AM by Yamahawk »
Edmund Burke
Romans 8:28
Job 13:15
