Author Topic: Replacement speedo and tach?  (Read 852 times)
Offline Paintedseat
« on: March 12, 2018, 06:19:58 AM »
This is a question for the nontraditional owners. I'm looking for a minimal handlebar/dash area. I am considering this https://cognitomoto.com/collections/electronics/products/motogadget-monoscope-mini. However it is pretty damn expensive. But it is awesome because of its size. Does anyone know of another option that might be a little less expensive?
Re: Replacement speedo and tach?
« Reply #1 on: March 12, 2018, 06:53:34 AM »
A lot of guys use Drag Specialties. Here is an example...
https://www.lowbrowcustoms.com/mini-2-to-1-ratio-mechanical-speedometer-2-4-inch-black-face.html?gclid=CjwKCAjwypjVBRANEiwAJAxlIvZTL2y0f4uyLN7GRpczArSwJCQ_WloMMYRjANZwGERGR55s0UHpoBoCuUMQAvD_BwE
*Note:  this particular one may not have the proper ratio, I do not know what bike you have.
Offline gareyc
« Reply #2 on: March 12, 2018, 12:31:07 PM »
I currently have the drag specialties speedo and a non-name brand tach between my clip ons. The drag specialties has worked really well for the 600ish miles I have since installing it. The previous speedo vibrated itself to death. The need return spring detached and after attempting to glue it back it didn't work. Both gauges were 30 to 60 bucks if I remember correctly. The tach has held up well and it has probably 2000 to 2500 miles so far but the needle does bounce a little after 6500 rpm; though that's likely a cable issue.
Its definitely up to your taste. I'll say to be careful getting something that is definitely vibration resistant, but given the inherent risk with those gauges you may want to just spring for something a little more expensive but with less or no moving parts. If I were to do it all over, I would consider getting a speedo/tach all in one and go electronic or GPS.
Offline Paintedseat
« Reply #3 on: March 12, 2018, 02:07:39 PM »
Yeah I have the standard aftermarket gauge the 50 dollar ones. They suck. The speedo bounces around. The tach is worse it basically is worthless. This even after I replaced the cables. I want to ditch the current setup and go with an electronic tach connection instead of mechanical. Same with speedo. Plus the vibration and sound from these gauges is louder than the engine. It is nerve-racking. I guess I will just spend the money. It will be nice to have just that small dash.
