After replacing steering stem bearing and front end cleaning, I just started to re-connect all electrical connections on the bike front (in the headlight) and found 1 wire I'm unable to identify where it belongs to.
It is brown/white wire coming from combined turn/light/horn left handlebar switch , most right on attached picture.
Checking wiring diagram there should be no such wire??? (diagram attached). Diagram is from original owners manual and the same is in shop manual (K7 supplement info part). Diagram shows 10 wires but I have 11...
Bad is that wire was connected somewhere (has scratches on connector) but no idea where..
Does anybody have any info about it? Bike is K7 (model 1977), manufactured 10/73, all original.
Thanks
